Datasheet 3SP_Ethanol_1000 Package 110-202 (Spec Sensors) - 2
| Manufacturer | Spec Sensors |
| Description | 15x15 Ethanol Sensor 1000 ppm Package 110-202 |
| Pages / Page | 5 / 2 — 3SP_Ethanol_1000 Package 110-202. January 2017. CROSS SENSITIVITY. … |
| File Format / Size | PDF / 503 Kb |
3SP_Ethanol_1000 Package 110-202. January 2017. CROSS SENSITIVITY. Gas/Vapor. Concentration. Typical Response PPM Ethanol
3SP_Ethanol_1000 Package 110-202 January 2017 CROSS SENSITIVITY Gas/Vapor Concentration Typical Response PPM Ethanol
Methane 500 ppm < 5 Ammonia 100 ppm < 5 Nitrogen Dioxide 10 ppm < 5 Hydrogen Sulfide 25 ppm 63.2 Carbon Monoxide 400 ppm 251.4 Ozone 5 ppm < 5 Sulfur Dioxide 20 ppm 11.6 Nitric Oxide (NO) 50 ppm 54.5 Chlorine 10 ppm -14.3 n-Heptane 500 ppm -12.6
TEMPERATURE EFFECT
Temperature fluctuations have a predictable, easily compensated effect on the sensor signal
The figures at below shows the typical Temperature dependency the output and baseline of 3SP_Ethanol_1000 sensors under constant humidity of 40-50 % RH. This is a very uniform and repeatable effect, easily compensated for in hardware or software. PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of the SPEC Copyright © 2011-2017, SPEC Sensors LLC Sensors standard warranty. Production processing does not necessarily include testing of all parameters.
