Datasheet MAX32625 (Analog Devices) - 6
DescriptionUltra-Low-Power Arm Cortex-M4 with FPU-Based Microcontroller (MCU) with 512KB Flash and 160KB SRAM
Pages / Page28 / 6 — Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. …
File Format / SizePDF / 806 Kb
Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. POWER SUPPLIES
Electrical Characteristics PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS POWER SUPPLIES
MAX32625/MAX32626 Ultra-Low-Power Arm Cortex-M4 with FPU-Based Microcontroller (MCU) with 512KB Flash and 160KB SRAM
(Limits are 100% tested at TA = +25ºC and TA = +85ºC. Limits over the operating temperature range and relevant supply voltage range are guaranteed by design and characterization. Specifications marked GBD are guaranteed by design and not production tested. Specifications to -30°C are guaranteed by design and are not production tested.)
VDD18 1.71 1.8 1.89 VDD12 1.14 1.2 1.26 Supply Voltage VRTC 1.75 1.8 1.89 V VDDIO 1.71 1.8 3.6 VDDIOH VDDIOH must be ≥ VDDIO 1.71 1.8 3.6 1.2V Internal Regulator VREG12 1.14 1.2 1.26 V Power-Fail Reset Voltage VRST Monitors VDD18 1.61 1.7 V Power-On Reset Voltage VPOR Monitors VDD18 1.5 V RAM Data Retention Voltage VDRV VDD12 supply, retention in LP1 0.930 mV Measured on the VDD12 pin and execut- VDD12 Dynamic ing code from cache memory, all inputs Current, LP3 Mode IDD12_DLP3 are tied to V 106 μA/MHz SS or VDD18, outputs do not source/sink any current, PMU disabled 96MHz oscillator selected as system clock, measured on the VDD12 pin and execut- ing code from cache memory, all inputs 87 are tied to VSS or VDD18, outputs do not VDD12 Fixed Current, LP3 source/sink any current Mode IDD12_FLP3 μA 4MHz oscillator selected as system clock, measured on the VDD12 pin and execut- ing code from cache memory, all inputs 39 are tied to VSS or VDD18, outputs do not source/sink any current 96MHz oscillator selected as system clock, measured on the VDD18 pin and execut- ing code from cache memory, all inputs 366 are tied to VSS or VDD18, outputs do not VDD18 Fixed Current, LP3 source/sink any current Mode IDD18_FLP3 μA 4MHz oscillator selected as system clock, measured on the VDD18 pin and execut- ing code from cache memory, all inputs 33 are tied to VSS or VDD18, outputs do not source/sink any current VDD12 Dynamic Measured on the VDD12 pin, ARM in sleep Current, LP2 Mode IDD12_DLP2 mode, PMU with two channels active 27 μA/MHz www.maximintegrated.com Maxim Integrated │ 6 Document Outline General Description Applications Benefits and Features Simplified Block Diagram Absolute Maximum Ratings Package Information 63 WLP 68 TQFN Electrical Characteristics Electrical Characteristics - ADC Electrical Characteristics - USB Electrical Characteristics - SPI Master / SPIX Master Electrical Characteristics - SPI Slave Electrical Characteristics - I2C Bus Pin Configurations Pin Description Detailed Description MAX32625/MAX32626 ARM Cortex-M4 with FPU Processor Power Operating Modes Low Power Mode 0 (LP0) Low Power Mode 1 (LP1) Low Power Mode 2 (LP2) Low Power Mode 3 (LP3) Analog-to-Digital Converter Pulse Train Engine Clocking Scheme Interrupt Sources Real-Time Clock and Wake-Up Timer General-Purpose I/O and Special Function Pins CRC Module Watchdog Timers Programmable Timers Serial Peripherals USB I2C Master and Slave SPI (Master) SPI (Slave) SPI (Execute in Place (SPIX) Master) UART 1-Wire Master Peripheral Management Unit (PMU) Additional Documentation Development and Technical Support Trust Protection Unit (TPU) (MAX32626 Only) Applications Information General-Purpose I/O Matrix Typical Application Circuit Ordering Information Revision History
