Datasheet HT75Rxx-7 (Holtek) - 6
ManufacturerHoltek
Description30V, 150mA TinyPower LDO with Protections
Pages / Page16 / 6 — HT75Rxx-7. 30V, 150mA TinyPowerTM LDO with Protections. Symbol. …
File Format / SizePDF / 929 Kb
HT75Rxx-7. 30V, 150mA TinyPowerTM LDO with Protections. Symbol. Parameter. Test Conditions. Min. Typ. Max. Unit
HT75Rxx-7 30V, 150mA TinyPowerTM LDO with Protections Symbol Parameter Test Conditions Min Typ Max Unit
HT75Rxx-7 30V, 150mA TinyPowerTM LDO with Protections Symbol Parameter Test Conditions Min. Typ. Max. Unit
ISHORT Output Short Current VIN=12V, force VOUT=0V — 150 — mA TSHD Shutdown Temperature — — 150 — oC TREC Recovery Temperature — — 125 — oC VIH CE Input High Threshold VOUT+1V ≤ VIN ≤ 30V 2.0 — — V VIL CE Input Low Threshold VOUT+1V ≤ VIN ≤ 30V — — 0.6 V RDIS Discharge Resistor VCE=0V, measure at VOUT — 300 — Ω Note: The dropout voltage is defined as the input voltage minus the output voltage that produces a 2% change in the output voltage from the value at VIN=VOUT+2V with a fixed load.
Typical Performance Characteristics
Test Condition: VIN=VOUT+2V, VCE=VIN, IOUT=10mA, CIN=1μF, COUT=1μF, Ta=25ºC, unless otherwise noted
Line Regulation: HT75RC0-7(IOUT=10mA) ISS vs VCE: HT75RC0-7(IOUT=0mA) ISS vs VIN: HT75RC0-7(IOUT=0mA) VOUT vs IOUT: HT75RC0-7 ISHD vs VIN: HT75RC0-7(IOUT=0mA) Dropout Voltage: HT75RC0-7
Rev. 1.00 6 May 13, 2025 Document Outline Features Applications General Description Selection Table Block Diagram Pin Assignment Pin Description Absolute Maximum Ratings Recommended Operating Range Electrical Characteristics Typical Performance Characteristics Application Circuits Basic Circuit High Output Current Positive Voltage Regulator Circuit for Increasing Output Voltage Constant Current Regulator Dual Supply Circuit Application Information External Circuit OCP and OTP Protections Fast Output Discharging Function Input Capacitor CIN Considerations Output Capacitor COUT Considerations Thermal Considerations Power Dissipation Calculation Package Information 3-pin SOT89 Outline Dimensions 5-pin SOT23 Outline Dimensions
