Datasheet MCR106 (Digitron Semiconductors)
ManufacturerDigitron Semiconductors
Description2.55 A Silicon Controlled Rectifier
Pages / Page3 / 1 — High-reliability discrete products. and engineering services since 1977. …
File Format / SizePDF / 576 Kb
High-reliability discrete products. and engineering services since 1977. FEATURES. MAXIMUM RATINGS. Rating. Symbol. Value. Unit
Datasheet MCR106 Digitron Semiconductors
MCR106 SERIES
SILICON CONTROLLED RECTIFIERS
and engineering services since 1977 FEATURES
Available as “HR” (high reliability) screened per MIL-PRF-19500, JANTX level. Add “HR” suffix to base part number. Available as non-RoHS (Sn/Pb plating), standard, and as RoHS by adding “-PBF” suffix.
MAXIMUM RATINGS
Rating Symbol Value Unit Peak repetitive off-state voltage
(1) (TJ = -40 to +110°C, sine wave, 50 to 60Hz, gate open) MCR106-1 30 MCR106-2 60 MCR106-3 VDRM 100 V MCR106-4 VRRM 200 MCR106-5 300 MCR106-6 400 MCR106-7 500 MCR106-8 600
On-state RMS current
(180° conduction angles, TC = 93°C) IT(RMS) 4.0 A
Average on-state current
(180° conduction angles, TC = 93°C) IT(AV) 2.55 A
Peak non-repetitive surge current
I A (half-cycle, sine wave, 60Hz, T TSM J = 110°C) 25
Circuit fusing consideration
(t = 8.3ms) I2t 2.6 A2s
Forward peak gate power
(pulse width ≤ 1.0µs, TC = 93°C) PGM 0.5 W
Forward average gate power
(t = 8.3ms, TC = 93°C) PG(AV) 0.1 W
Forward peak gate current
(pulse width ≤ 1.0µs, TC = 93°C) IGM 0.2 A
Peak reverse gate voltage
V V (pulse width ≤ 1.0µs, T RGM C = 93°C) 6.0
Operating junction temperature range
TJ -40 to +110 °C
Storage temperature range
Tstg -40 to +150 °C
Mounting torque
(2) - 6.0 In. lb. Note 1: VDRM and VRRM for al types can be applied on a continuous basis. Ratings apply for zero or negative gate voltage; positive gate voltage shal not be applied concurrent with negative potential on the anode. Blocking voltages shal not be tested with a constant current source such that the voltage ratings of the devices are exceeded. Note 2: Torque rating applies with use of compression washer. Mounting torque in excess of 6 in. lb. does not appreciably lower case-to-sink thermal resistance. Anode lead and heatsink contact pad are common. For soldering purposes, soldering temperatures should not exceed +200°C. For optimum results, an activated flux is recommended.
THERMAL CHARACTERISTICS Characteristic Symbol Maximum Unit Thermal resistance, junction to case
RӨJC 3.0 °C/W
Thermal resistance, junction to ambient
RӨJA 75 °C/W
Lead solder temperature
T °C (lead length ≥ 1/8” from case, 10s max) L 260
ELECTRICAL CHARACTERISTICS
(TC = 25°C unless otherwise specified)
Characteristic Symbol Min Typ Max Unit OFF CHARACTERISTICS Peak forward or reverse blocking current
IDRM, µA (VAK = Rated VDRM or VRRM, RGK = 1000Ω) IRRM Rev. 20130115
