Datasheet OPA186 (Texas Instruments) - 5
| Manufacturer | Texas Instruments |
| Description | Single, 24-V, low-power (90 μA) 5-μV-offset zero-drift op amp with rail-to-rail input and o |
| Pages / Page | 49 / 5 — OPA186. , OPA2186. , OPA4186. www.ti.com. 6 Specifications 6.1 Absolute … |
| File Format / Size | PDF / 2.6 Mb |
OPA186. , OPA2186. , OPA4186. www.ti.com. 6 Specifications 6.1 Absolute Maximum Ratings. MIN. MAX. UNIT. 6.2 ESD Ratings. VALUE
link to page 5 link to page 5 link to page 5 link to page 5
OPA186 , OPA2186 , OPA4186 www.ti.com
SBOS968C – JUNE 2022 – REVISED JULY 2023
over operating free-air temperature range (unless otherwise noted)(1)
MIN MAX UNIT
VS Supply voltage, VS = (V+) – (V–) 26 V Common-mode (V–) –0.5 (V+) + 0.5 Input voltage V Differential (V+) – (V–) + 0.2 Output short-circuit(2) Continuous TJ Operating junction temperature -40 150 °C Tstg Storage temperature -65 150 °C (1) Operation outside the Absolute Maximum Ratings may cause permanent device damage. Absolute Maximum Ratings do not imply functional operation of the device at these or any other conditions beyond those listed under Recommended Operating Conditions. If used outside the Recommended Operating Conditions but within the Absolute Maximum Ratings, the device may not be fully functional, and this may affect device reliability, functionality, performance, and shorten the device lifetime. (2) Short-circuit to ground, one amplifier per package.
6.2 ESD Ratings VALUE UNIT
Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001(1) ±1000 V(ESD) Electrostatic discharge V Charged-device model (CDM), per JANSI/ESDA/JEDEC JS-002(2) ±500 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
6.3 Recommended Operating Conditions
MIN NOM MAX UNIT
Supply Single supply 4.5 24 VS V voltage Dual supply ±2.25 ±12 TA Specified temperature –40 125 °C Copyright © 2023 Texas Instruments Incorporated Submit Document Feedback 5 Product Folder Links: OPA186 OPA2186 OPA4186 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information: OPA186 6.5 Thermal Information: OPA2186 6.6 Thermal Information: OPA4186 6.7 Electrical Characteristics 6.8 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Rail-to-Rail Inputs 7.3.2 Phase-Reversal Protection 7.3.3 Input Bias Current Clock Feedthrough 7.3.4 EMI Rejection 7.3.4.1 EMIRR +IN Test Configuration 7.3.5 Electrical Overstress 7.3.6 MUX-Friendly Inputs 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.1.1 Basic Noise Calculations 8.2 Typical Applications 8.2.1 High-Side Current Sensing 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curve 8.2.2 Bridge Amplifier 8.3 Power Supply Recommendations 8.4 Layout 8.4.1 Layout Guidelines 8.4.2 Layout Example 9 Device and Documentation Support 9.1 Device Support 9.1.1 Development Support 9.1.1.1 PSpice® for TI 9.1.1.2 TINA-TI™ Simulation Software (Free Download) 9.2 Documentation Support 9.2.1 Related Documentation 9.3 Receiving Notification of Documentation Updates 9.4 Support Resources 9.5 Trademarks 9.6 Electrostatic Discharge Caution 9.7 Glossary 10 Mechanical, Packaging, and Orderable Information
