Datasheet AP6A255Q (Diodes)
| Manufacturer | Diodes |
| Description | 5.5V to 100V Input Automotive Grade, 2.5A Standard Buck Converter |
| Pages / Page | 18 / 1 — AP6A255Q/AP6A355Q. 5.5V TO 100V INPUT AUTOMOTIVE GRADE, 2.5A AND 3.5A … |
| File Format / Size | PDF / 1.3 Mb |
AP6A255Q/AP6A355Q. 5.5V TO 100V INPUT AUTOMOTIVE GRADE, 2.5A AND 3.5A STANDARD BUCK CONVERTER. Description. Pin Assignments
AP6A255Q/AP6A355Q 5.5V TO 100V INPUT AUTOMOTIVE GRADE, 2.5A AND 3.5A STANDARD BUCK CONVERTER Description Pin Assignments
The AP6A255Q/AP6A355Q is an internally compensated, standard DC-DC buck converter with a default frequency of 300kHz. The device GND 1 8 SW fully integrates a 500mΩ high-side power MOSFET power MOSFET to provide highly efficient step-down DC-DC conversion. 2 7 VIN BST The AP6A255Q/AP6A355Q device is easily used by minimizing the external component count due to its adoption of Constant On-Time EPAD (COT) control to achieve fast transient response, easy loop 9 stabilization, and low output voltage ripple. EN 6 3 NC The AP6A255Q/AP6A355Q design is optimized for Electromagnetic Interference (EMI) reduction. The device has a proprietary gate driver NC 4 5 FB scheme to resist switching node ringing without sacrificing MOSFET turn-on and turn-off times, which reduces high frequency radiated EMI noise caused by MOSFET switching.
SO-8EP
The AP6A255Q/AP6A355Q is available in the standard Green SO-8EP package.
Features Applications
• Qualified for Automotive Applications • General-purpose point-of-load DC/DC power conversion • AEC-Q100 Qualified with the Following Results • Automotive infotainments ▪ Device Temperature Grade 1: -40° C to +125° C TA • Telecommunication systems ▪ Device HBM ESD Classification Level 1C • Distributed power systems ▪ Device CDM ESD Classification Level C5 • Home audio devices • Functional Safety-Capable ISO26262 – Documentation • Consumer electronics Available to Aid Functional Safety System Design • Network systems • VIN 5.5V to 100V • FPGA, DSP, and ASIC supplies • 1.2V ±1.5% VREF • Green electronics • Continuous Output Current – AP6A255Q: 2.5A – AP6A355Q: 3.5A • VOUT Adjustable from 1.2V to 50V • Overcurrent Protection (OCP) • Thermal Protection •
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
Halogen and Antimony Free. “Green” Device (Note 3)
The AP6A255Q/AP6A355Q are suitable for automotive applications requiring specific change control; these parts are AEC-Q100 qualified, PPAP capable, and manufactured in IATF 16949 certified facilities. https://www.diodes.com/quality/product-definitions/
Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. AP6A255Q/AP6A355Q 1 of 18 May 2025 Document number: DS47149 Rev. 1 - 2
www.diodes.com
