Datasheet NTE7100 (NTE Electronics)
ManufacturerNTE Electronics
DescriptionProtector IC for Stereo Power Amplifier
Pages / Page2 / 1 — NTE7100. Integrated Circuit. Protector IC for Stereo Power Amplifier. …
File Format / SizePDF / 34 Kb
NTE7100. Integrated Circuit. Protector IC for Stereo Power Amplifier. Description:. Features:. Absolute Maximum Ratings:
Datasheet NTE7100 NTE Electronics
NTE7100 Integrated Circuit Protector IC for Stereo Power Amplifier Description:
The NTE7100 is a monolithic integrated circuit in an 8–Lead SIP type package designed for protecting stereo power amplifiers and loudspeakers.
Features:
D Work Stably Within a Wide Power Supply Range: VCC = 25V to 60V D Contains a Relay Driver: I6 = 80mA max D Pin3 can be used for Either a Latching Function or Automatic Resetting Function (In Both Overload Detection and Output Offset Detection, Either Function can be Selected) D Single Power Supply D Both Positive and Negative Output Offset can be Detected Through the Same Pin (Output Off- set Detection Through Pin2) D AC Voltage can be Detected (For AC–Power–OFF Mute Through Pin4) D The Time Delay from Amplifier Power ON to Relay ON can be Freely Set by Selecting External Components. (For AC–Power–ON Mute Through Pin7)
(TA = +25°C unless otherwise specified) Power Supply Voltage, VCC . 60V Allowable Power Dissipation (TA = +75°C), PD . 320mW Maximum Voltage At: Pin4, V4max . 10V Pin8, V8max . 8V Pin7, V7max . 8V Maximum Current At: Pin6, I6max . 80mA Pin1, I1max . 3mA Pin2, I2max . ±3mA Operating Temperature Range, Topr . –20° to +75°C Storage Temperature Range, Tstg . –40° to +125°C
Recommended Operating Conditions: Parameter Symbol Test Conditions Min Typ Max Unit
Supply Voltage VCC 25 45 60 V
