Datasheet DMMT3904WQ (Diodes)
ManufacturerDiodes
DescriptionDual NPN, 40V, 0.2A, SOT363
Pages / Page6 / 1 — DMMT3904WQ. 40V MATCHED PAIR NPN SMALL SIGNAL TRANSISTOR IN SOT363. …
File Format / SizePDF / 466 Kb
DMMT3904WQ. 40V MATCHED PAIR NPN SMALL SIGNAL TRANSISTOR IN SOT363. Features. Mechanical Data
Datasheet DMMT3904WQ Diodes
DMMT3904WQ 40V MATCHED PAIR NPN SMALL SIGNAL TRANSISTOR IN SOT363 Features Mechanical Data
BVCEO > 40V Case: SOT363 IC = 200mA High Collector Current Case Material: Molded Plastic, “Green” Molding Compound. Pair of NPN Transistors that are Intrinsically Matched (Note 1) UL Flammability Classification Rating 94V-0 2% Matching on Current Gain (hFE) Moisture Sensitivity: Level 1 per J-STD-020 2mV Matching on Base-Emitter Voltage (VBE) Terminals: Finish  Matte Tin Finish. Solderable per Fully Internally Isolated in a Small Surface Mount Package MIL-STD-202, Method 208
Totally Lead-Free & Fully RoHS Compliant (Notes 2 & 3)
Weight: 0.006 grams (Approximate)
Halogen and Antimony Free. "Green" Device (Note 4) The DMMT3904WQ is suitable for automotive applications Applications requiring specific change control; this part is AEC-Q101 qualified, PPAP capable, and manufactured in IATF 16949
Current Mirrors
certified facilities.
Differential and Instrumentation Amplifiers
https://www.diodes.com/quality/product-definitions/
Comparators SOT363 Top View Device Schematic and Pin-Out Top View
Ordering Information
(Note 5)
Part Number Compliance Marking Reel Size (inches) Tape Width (mm) Quantity per Reel
DMMT3904WQ-7-F Automotive K4A 7 8 3,000 Notes: 1. Intrinsically matched pair as this is built with adjacent die from the same wafer. 2. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 3. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 4. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 5. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/.
Marking Information
SOT363 K4A = Product Type Marking Code YM = Date Code Marking Y = Year (ex: H = 2020) M = Month (ex: 2 = February) Date Code Key
Year 2014 … 2020 2021 2022 2023 2024 2025 2026 2027 2028 2029 Code
B … H I J K L M N O P R
Month Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec Code
1 2 3 4 5 6 7 8 9 O N D DMMT3904WQ 1 of 6 July 2020 Document number: DS42397 Rev. 1 - 2
www.diodes.com
© Diodes Incorporated
