Datasheet NTCSC0201E3.....T (Vishay)
ManufacturerVishay
DescriptionSMD 0201, Commercial Grade NTC Thermistors
Pages / Page3 / 1 — NTCSC0201E3...T. SMD 0201, Commercial Grade NTC Thermistors. FEATURES. …
File Format / SizePDF / 103 Kb
NTCSC0201E3...T. SMD 0201, Commercial Grade NTC Thermistors. FEATURES. LINKS TO ADDITIONAL RESOURCES. Design Tools. Calculators
Datasheet NTCSC0201E3.....T Vishay
NTCSC0201E3...T
www.vishay.com Vishay BCcomponents
SMD 0201, Commercial Grade NTC Thermistors FEATURES
• TCR ranging from -6.5 %/K at -40 °C to -2 %/K at 125 °C • Tolerance on R25 of ± 1 % • Suitable for wave or reflow soldering • NiSn terminations • cULus recognized, file E148885 (UL category XGPU2 / XGPU8)
• Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
Design Tools Calculators Models APPLICATIONS
• Temperature sensing, protection and compensation in
QUICK REFERENCE DATA
industrial, telecom and consumer applications.
PARAMETER VALUE UNIT
Examples are: Resistance value at 25 °C 10K to 100K Ω Tolerance on - Battery chargers R25-value ± 1 % B25/85-value 3435 to 4311 K - Power supplies Tolerance on B25/85-value 3 % - Office equipment Maximum power dissipation 70 mW - LED compensation at 25 °C Pmax25 Thermal time constant τ < 3 s This series is not recommended for automotive Dissipation factor D 1 mW/K applications. Operating temperature range at zero power (1) -40 to +125 °C
DESCRIPTION
Storage temperature range -40 to +125 °C Size 0201 (M0603) SMD chip thermistor with negative Weight 0.16 mg temperature coefficient (TCR) and matte tin (Sn) plated
Note
terminations. The device has no marking. (1) Zero power is considered as measuring power maximum 1 % of Pmax25
PACKAGING AGENCY APPROVALS
Available in 8 mm punched paper tape on reel package of 15 000 units. Agency approval documents, please see: www.vishay.com/ppg?29238&documents
CAUTIONS AND WARNINGS ON MOUNTING AND HANDLING DESIGN-IN SUPPORT
Please read the special instructions: For complete curve computation, please visit: see www.vishay.com/doc?29224. www.vishay.com/thermistors/ntc-rt-calculator/
ELECTRICAL DATA AND ORDERING INFORMATION R 25 R 25-TOL. B25/85 B25/85-TOL. SAP MATERIAL AND ORDERING NUMBER (
Ω
) (± %) (K) (± %)
10 000 1 3435 3 NTCSC0201E3103FLHT 22 000 1 3414 3 NTCSC0201E3223FLHT 47 000 1 4108 3 NTCSC0201E3473FXHT 100 000 1 4311 3 NTCSC0201E3104FXHT Revision: 24-Mar-2025
1
Document Number: 29243 For technical questions, contact: nlr@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
