Datasheet LTA 50 (Vishay) - 2
ManufacturerVishay
Description50 W Power Resistor Thick Film Technology
Pages / Page6 / 2 — LTA 50. TECHNICAL SPECIFICATIONS Dissipation and Associated. Power Rating …
File Format / SizePDF / 101 Kb
LTA 50. TECHNICAL SPECIFICATIONS Dissipation and Associated. Power Rating and Thermal Resistance of the Component
LTA 50 TECHNICAL SPECIFICATIONS Dissipation and Associated Power Rating and Thermal Resistance of the Component
LTA 50
www.vishay.com Vishay Sfernice
Onto a heatsink 50 W at +50 °C (case temp.) R
TH (j - c): 2.5 °C/W Free air: 2.5 W at +25 °C
Temperature Coefficient
See Performance table
Standard
± 150 ppm/°C
Dielectric Strength
1500 VRMS - 1 min
MIL STD 202
10 mA max.
Insulation Resistance
≥ 104 MΩ
Inductance
≤ 0.1 μH
PERFORMANCE TESTS CONDITIONS REQUIREMENTS
EN 60115-1
Momentary Overload
1.5 Pr / 5 s ± (0.5 % + 0.05 Ω) US < 1.5 UL EN 60115-1
Load Life
± (1 % + 0.05 Ω) 1000 h Pr at +25 °C AEC-Q200 rev. E conditions:
High Temperature Exposure
MIL-STD-202 method 108 ± (0.5 % + 0.05 Ω) 1000 h, +175 °C, unpowered AEC-Q200 rev. D conditions: JESD22 method JA-104
Temperature Cycling
± (1 % + 0.05 Ω) 1000 cycles, -55 °C to +125 °C dwell time -15 min AEC-Q200 rev. E conditions:
Humidity Bias
MIL-STD-202 method 103 ± (1 % + 0.05 Ω) 1000 h, 85 °C, 85 % RH, 10 % operating power AEC-Q200 rev. D conditions:
Operational Life
MIL-STD-202 method 108 ± (1 % + 0.05 Ω) 1000 h, 90/30, powered, +125 °C AEC-Q200 rev. E conditions:
ESD Human Body Model
AEC-Q200-002 ± (0.5 % + 0.05 Ω) 25 kVAD AEC-Q200 rev. E conditions: MIL-STD-202 method 204
Vibration
± (0.2 % + 0.05 Ω) 5 g’s for 20 min, 12 cycles test from 10 Hz to 2000 Hz AEC-Q200 rev. E conditions: MIL-STD-202 method 213
Mechanical Shock
± (0.2 % + 0.05 Ω) 100 g’s, 6 ms, 3.75 m/s 3 shocks/direction AEC-Q200 rev. E conditions:
Terminal Strength
± (0.25 % + 0.05 Ω) MIL-STD-202 method 211
SPECIAL FEATURES Resistance Values
≥ 0.01 ≥ 0.015 ≥ 0.1 ≥ 0.5
Tolerances
5 %, 10 % 1 %, 2 %, 5 %, 10 %
Typical Temperature Coefficient
± 900 ppm/°C ± 700 ppm/°C ± 250 ppm/°C ± 150 ppm/°C
(-55 °C to +155 °C)
Revision: 23-Jan-2025
2
Document Number: 50086 For technical questions, contact: sferfixedresistors@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
