Datasheet XL4015 (XLSemi) - 2
ManufacturerXLSemi
Description5A, 180KHz, 36V Buck DC to DC Converter in TO263-5L package
Pages / Page10 / 2 — Datasheet. 5A 180KHz 36V Buck DC to DC Converter XL4015. Pin …
File Format / SizePDF / 255 Kb
Datasheet. 5A 180KHz 36V Buck DC to DC Converter XL4015. Pin Configurations. Pin Number. Pin Name. Description
Datasheet 5A 180KHz 36V Buck DC to DC Converter XL4015 Pin Configurations Pin Number Pin Name Description
Figure2. Pin Configuration of XL4015 (Top View) Table 1 Pin Description
Ground Pin. Care must be taken in layout. This pin should be placed outside of the Schottky Diode to output capacitor 1 GND ground path to prevent switching current spikes from inducing voltage noise into XL4015. Feedback Pin (FB). Through an external resistor divider 2 FB network, FB senses the output voltage and regulates it. The feedback threshold voltage is 1.25V. Power Switch Output Pin (SW). SW is the switch node that 3 SW supplies power to the output. Internal Voltage Regulator Bypass Capacity. In typical system 4 VC application, The VC pin connect a 1uf capacity to VIN. Supply Voltage Input Pin. XL4015 operates from a 8V to 36V 5 VIN DC voltage. Bypass Vin to GND with a suitably large capacitor to eliminate noise on the input. Rev 1.5 www.xlsemi.com 2
