Datasheet AL3069Q (Diodes) - 5
ManufacturerDiodes
DescriptionAutomotive Display LED-Backlight Driver
Pages / Page18 / 5 — AL3069Q. Electrical Characteristics. Symbol. Parameter. Condition. Min. …
AL3069Q. Electrical Characteristics. Symbol. Parameter. Condition. Min. Typ. Max. Unit. Input Supply. VCC Regulator. Boost Gate Drive
AL3069Q Electrical Characteristics Symbol Parameter Condition Min Typ Max Unit Input Supply VCC Regulator Boost Gate Drive
(@TA = -40°C to +125°C, VIN = 12V, VEN = 5V, unless otherwise specified.)
IQ Quiescent Current No Switching — 3 — mA ISHDN Shutdown Supply Current VEN = 0 — 1 — µA VUVLO Undervoltage Lockout Voltage VIN Rising 3.7 4.0 4.3 V VHYS UVLO Hysteresis — — 200 — mV
VCC Regulator
VIN ≥ 5.5V — 5 — V VCC VCC Voltage VIN < 5.5V — VIN-0.5 — V — Load Regulation Load = 0 to 30mA — 5 — mV/mA — Line Regulation VIN = 12V to 33V — 0.3 — mV/V
Boost Gate Drive
tRISE OUT Pin Rise Time (Note 7) OUT Pin Load = 1nF — 30 — ns tFALL OUT Pin Fall Time (Note 7) OUT Pin Load = 1nF — 30 — ns
High-Frequency Oscillator
fOSC1 Switch Frequency RT = 100kΩ — 500 — kHz — Switch Frequency Range — 0.1 — 1 MHz DMAX Max Duty Cycle RT = 100kΩ 80 90 — % tON_TIME Minimum On-Time (Note 7) — — 100 — ns
Enable Logic and Dimming Logic
VEN_H EN High Voltage — 2.4 — — V VEN_L EN Low Voltage — — — 0.5 V VPWMD_H — 2.5 — — V PWM Logic for External Dimming VPWMD_L — — — 0.3 V
Power Switch Drive
VLIMIT Current-Limit Threshold Voltage — 480 540 600 mV VLIMIT2 D/L Short Threshold Voltage — 720 800 880 mV tLEB Current-Sense LEB Time (Note 7) — — 100 — ns
Compensation and Soft-Start (COMP Pin)
IO_H Sourcing Current VCOMP = 0.5V — 120 — µA IO_L Sinking Current VCOMP = 2V — 120 — µA Note: 7. Guaranteed by design. AL3069Q 5 of 18 July 2025 Document number: DS46159 Rev. 2 - 2
www.diodes.com
