Datasheet TCD2905CF (Toshiba) - 5
ManufacturerToshiba
DescriptionCCD Image Sensor
Pages / Page24 / 5 — TCD2905CF. Note. 2:. Sensitivity. is. defined. for. each. color. of. …
File Format / SizePDF / 388 Kb
TCD2905CF. Note. 2:. Sensitivity. is. defined. for. each. color. of. signal. outputs. average. when. the. photosensitive. surface. is. applied. with. the. light
TCD2905CF Note 2: Sensitivity is defined for each color of signal outputs average when the photosensitive surface is applied with the light
TCD2905CF Note 2: Sensitivity is defined for each color of signal outputs average when the photosensitive surface is applied with the light of uniform illumination and uniform color temperature. Note 3: PRNU (1) is defined for each color on a single chip by the expressions below when the photosensitive surface is applied with the light of uniform illumination and uniform color temperature. ∆X PRNU (1) = × 100 (%) X Where X is average of total signal output and ∆X is the maximum deviation from X . The amount of incident light is shown below. Red = 1/2・SE Green = 1/2・SE Blue = 1/4・SE Note 4: PRNU (3) is defined as maximum voltage with next pixel, where measured at 5% of SE (typ.) Note 5: Register imbalance is defined as follows. 10799 xn ∑ − (n x + 1) n = 1 RI = ∗ (%) 100 10799 ∗ X Note 6: VSAT is defined as minimum saturation output of all effective pixels. Note 7: Definition of SE VSAT SE = (lx・s) RG Note 8: VDRK is defined as average dark signal voltage of all effective pixels. DSNU is defined as different voltage between VDRK and VMDK when VMDK is maximum dark signal voltage. VDRK VMDK DSNU Note 9: DC signal output voltage is defined as follows. Reset Noise Voltage is defined as follows. VRSN OS VMS VOS SS 5 2003-2-3
