Datasheet MA2J1110G (Panasonic)
ManufacturerPanasonic
DescriptionSwitching Diode 80V, 100mA in SMini2-F3 package
Pages / Page4 / 1 — This product complies with the RoHS Directive (EU 2002/95/EC). Switching …
File Format / SizePDF / 209 Kb
This product complies with the RoHS Directive (EU 2002/95/EC). Switching Diodes MA2J1110G. Silicon epitaxial planar type
Datasheet MA2J1110G Panasonic
For switching circuits
■ Package • Allowing high-density mounting
• Short reverse recovery time trr
• Small terminal capacitance Ct
• High breakdown voltage: VR = 80 V • Code
SMini2-F3
• Pin Name
1: Anode
2: Cathode di
p
Pl
lan nclu
ea
e
se
pla m d m des
ne ain ain foll
htt visit
d te t o
p:/ fo
/w llo dis disc nan enan wing
ww wi co on ce c fo
.se ng ntin tin ty e ty ur
mi UR ue ued pe pe Pro
co L a d t ty
du
n.p bo yp pe
ct
life
an ut e
d
as lat
cy
on es
cle
ic. t in
sta
co fo
ge
.jp rm
/en at
i
o
n. M
Di ain
sc te
on na
tin nc
ue e/
d ■ Features ■ Absolute Maximum Ratings Ta = 25°C
Parameter Symbol Reverse voltage VR Maximum peak reverse voltage
Forward current VRM
IF Peak forward current IFM Non-repetitive peak forward
surge current * IFSM Junction temperature Tj Storage temperature Tstg Note) *: t = 1 s Rating Unit 80 V 80 V 100 mA 225 mA 500 mA 150 °C −55 to +150 °C ■ Marking Symbol: 1B ue ■ Electrical Characteristics Ta = 25°C ± 3°C
Symbol ce
/D
isc
on
tin Parameter Forward voltage VF Reverse voltage VR Reverse current IR an Terminal capacitance int en Reverse recovery time * Ct
trr Conditions Min IF = 100 mA
IR = 100 µA Typ Max Unit 0.95 1.20 V 100 nA 1.2 pF 3 ns 80 V VR = 75 V VR = 0 V, f = 1 MHz 0.6 IF = 10 mA, VR = 6 V
Irr = 0.1 IR , RL = 100 Ω Ma Note) 1. Measuring methods are based on JAPANESE INDUSTRIAL STANDARD JIS C 7031 measuring methods for diodes.
2. Absolute frequency of input and output is 100 MHz.
3. *: trr measurement circuit
Bias Application Unit (N-50BU) Input Pulse
tp tr
10% A
VR
Pulse Generator
(PG-10N)
Rs = 50 Ω Publication date: November 2007 90%
tp = 2 µs
tr = 0.35 ns
δ = 0.05 Wave Form Analyzer
(SAS-8130)
Ri = 50 Ω SKF00091AED Output Pulse t
IF trr
t
Irr = 0.1 IR
IF = 10 mA
VR = 6 V
RL = 100 Ω 1
