Datasheet EPC23108 (Efficient Power Conversion) - 5
ManufacturerEfficient Power Conversion
Description100V, 35 A ePower Stage IC
Pages / Page17 / 5 — eGaN® IC DATASHEET. Electrical Characteristics. Electrical …
eGaN® IC DATASHEET. Electrical Characteristics. Electrical Characteristics# (continued). SYMBOL. PARAMETER. TEST CONDITIONS. MIN
eGaN® IC DATASHEET Electrical Characteristics Electrical Characteristics# (continued) SYMBOL PARAMETER TEST CONDITIONS MIN
eGaN® IC DATASHEET
EPC23108
(continued)
Electrical Characteristics# (continued) SYMBOL PARAMETER TEST CONDITIONS MIN TYP MAX UNITS Power FETs Quiescent Currents – include internal biasing circuits(3)
IQ_VIN-SW Quiescent current (VIN to SW) HSIN = 0 V, VIN = 100 V, SW = 0 V 230 µA IQ_SW-PGND Quiescent current (SW to PGND) LSIN = 0 V, VIN = 100 V, SW = 100 V 3.4 mA HS I IN = 0 V, VIN = 100 V 119 230 Q_VIN-PGND Quiescent current (VIN to PGND) µA HSIN = 0 V, VIN = 48 V 160
Dynamic Characteristics (Logic Input to Output Switching Node SW)
(See Figure 3 for Timing Diagram) PW_min Minimum pulse width 50% to 50% width, LSIN and HSIN (5) 30 (1) ns tFilter Input filter cutoff time 50% to 50% width, LSIN and HSIN 15 tShutdown Shutdown propagation delay 50% to 50% width, HS and LS FET turn-OFF 41 (1) t_delayHS_on High-side ON propagation delay SW = 0 V and HS FET turn-ON 41 t_delayLS_on Low-side ON propagation delay SW = 48 V and LS FET turn-ON 41 t_delayHS_off High-side OFF propagation delay SW = 48 V and HS FET turn-OFF 41 t_delayLS_off Low-side OFF propagation delay SW = 0 V and LS FET turn-OFF 41 t_match ns on Delay matching LSoff to HSon LS turn-OFF to HS turn-ON 3.5 t_matchoff Delay matching HSoff to LSon HS turn-OFF to LS turn-ON 4.6 t_lockout Cross-conduction lockout time LS turn-OFF to HS turn-ON or HS turn-OFF to LS turn-ON – no dead time on LSIN HSIN inputs 5 t_rise SW rise time at high-side FET turn-ON HS turn-ON current exiting from SW node, 0 V to 48 V, SW_HS10 (motor drive, hard switching) RBOOT = 10 Ω, ILOAD = 5 A (4) 5 t_fall SW fall time at low-side FET turn-ON LS turn-ON current entering the SW node, 48 V to 0 V, SW_LS10 (motor drive, hard switching) RDRV = 10 Ω, ILOAD = 5 A (4) 5 (1) Not tested, guaranteed by design (2) ISW is positive when exiting from SW node (3) The quiescent currents include the power FET IDSS as well as the internal circuits biasing currents (4) Measured on application board EPC91128 (5) There is no max limit for the pulse width length in time, as long as the voltage supply is not below the power on reset threshold limit. PW_max for the high- side FET depends also on the external bootstrap capacitance value. If the CBOOT voltage fal s below power on reset threshold voltage, the high-side GaN FET is switched OFF. The high-side circuit can be biased from an external 5 V floating voltage supply to al ow infinite turn on of the high-side FET. EPC – POWER CONVERSION TECHNOLOGY LEADER | EPC-CO.COM | ©2026 | For more information: info@epc-co.com | 5
