Datasheet ECS-3225SMVQ (ECS Inc.)
ManufacturerECS Inc.
DescriptionThe ECS-3225SMVQ tight stability, automotive-grade MultiVolt crystal oscillators are ideal for low-power, portable, industrial and IoT applications.
Pages / Page2 / 1 — ECS-3225SMVQ. Request a Sample. OPERATING CONDITIONS / ELECTRICAL …
File Format / SizePDF / 321 Kb
ECS-3225SMVQ. Request a Sample. OPERATING CONDITIONS / ELECTRICAL CHARACTERISTICS. PARAMETERS. CONDITIONS. UNITS
Datasheet ECS-3225SMVQ ECS Inc.
ECS-3225SMVQ
SMD MultiVolt™ Crystal Oscillator The ECS-3225SMVQ is a miniature SMD AEC-Q200 HCMOS Tight Stability Oscillator with MultiVolt™ capability of 1.62 ~ 3.63 V with a tight stability of ±20 ppm -40 ~ +125°C. The 3.2 x 2.5 x 1.2 mm ceramic package is ideal for Automotive and Industrial applications.
Request a Sample OPERATING CONDITIONS / ELECTRICAL CHARACTERISTICS PARAMETERS CONDITIONS ECS-3225SMVQ UNITS ECS-3225SMVQ SMD XO MIN TYP MAX
Frequency Range 8.000 60.000 MHz -40 ~ +125°C * Frequency Stability ±20 ppm (DS Opt) Supply Voltage 1.62 3.63 V Output Load CMOS 15 pF Output voltage Level VOL: 0.2 Vdd max. / VOH: 0.8 Vdd min.V DC Rise & Fall time 20% Vdd – 80% Vdd 5 nS Start Up Time 10 mS • 3.2 x 2.5 mm Footprint Phase Jitter 12 kHz to 20 MHz 0.362 0.5 pS • Extended Temp Range Duty Cycle @ ½ Vdd 45/55 % • RoHS Compliant Input Current • Wide Supply Voltage 6 10 mA (No Load) • Low Jitter • Compatible with 1.8V, 2.5V or Standby Current 10 µA 3.3V Power Supply Operating Temp* S Option -40 +125 °C • Storage Temp -55 +125 °C
DIMENSIONS (mm)
* Frequency Stability includes initial tolerance, temperature, supply voltage and load change reflow frequency shift, and aging.
PAD CONNECTIONS
1 Tri-state 2 Gnd 3 Output 4 Vdd
Tri State Function
Pin 1 Output
Figure 2)
Suggested Land Pattern 0.7 * Vdd Min or NC Active 0.3 * Vdd Max. High Impedance
Figure 1)
Top, Side, and Bottom views
PART NUMBERING GUIDE: Example ECS-3225SMVQ-500-DS-TR ECS - SERIES FREQUENCY - * STABILITY TEMP RANGE - PACKAGING ABBREVIATION
3225SMVQ 500 = 50.000 MHz D = ±20 ppm N = -40 ~ +85°C -TR = Tape & ECS 3.2 x 2.5 mm See Developed F = ±10 ppm P = -40 ~ +105°C Reel AEC-Q200 MultiVolt Frequencies Pg. 2 G = ±5 ppm †S = -40 ~ +125°C 1K/Reel Oscillator Tight Stability † 20 ppm is only option for -40 ~ +125°C temperature range. Rev. 2024
15351 West 109th Street
Lenexa, KS 66219
Phone: 913.782.7787
Fax: 913.782.6991
www.ecsxtal.com
