Datasheet SPX3819 (MaxLinear) - 3
ManufacturerMaxLinear
Description500mA Low-Noise LDO Voltage Regulatorin
Pages / Page13 / 3 — SPX3819. 500mA Low-Noise LDO Voltage Regulator. Parameter. Min. Typ. Max. …
SPX3819. 500mA Low-Noise LDO Voltage Regulator. Parameter. Min. Typ. Max. Units. Conditions. PIN ASSIGNMENT. PIN DESCRIPTION. Pin #. Name
SPX3819 500mA Low-Noise LDO Voltage Regulator Parameter Min Typ Max Units Conditions PIN ASSIGNMENT PIN DESCRIPTION Pin # Name
SPX3819
SPX3819 500mA Low-Noise LDO Voltage Regulator Parameter Min. Typ. Max. Units Conditions
Current Limit (ILIMIT) 800 mA VOUT=0V 950 • 300 µVRMS IL = 10mA, CL = 1.0µF, CIN = 1µF, (10Hz – 100kHz) Output Noise (eNO) 40 µVRMS IL = 10mA, CL = 1.0µF, CBYP = 1µF, CIN = 1µF, (10Hz – 100kHz) Input Voltage Level Logic Low (VIL) 0.4 V OFF Input Voltage Level Logic High (VIH) 2 V ON ENABLE Input Current 0.01 2 µA VIL ≤ 0.4V 3 20 VIH ≥ 2.0V Note 2: Not applicable to output voltage 2V or less.
PIN ASSIGNMENT
Fig. 2: SPX3819 Pin Assignment
PIN DESCRIPTION Pin # Pin # Pin # Name nSOIC DFN SOT-23 Description
VIN 2 3 1 Supply Input GND 5, 6, 7, 8 7 2 Ground VOUT 3 5 5 Regulator Output EN 1 1 3 Enable(input). CMOS compatible control input. Logic high – enable; logic low or open = shutdown ADJ Adjustable part only. Feedback input. Connect to resistive voltage- divider network 4 8 4 BYP Fixed version only. Internal reference bypass pin. Connect 10nF to ground to reduce thermal noise on the output. NC - 2, 4, 6 - No Connect 3/13 Rev. 2.0.5
