Datasheet nRF51822 - 103
DescriptionMultiprotocol Bluetooth low energy/2.4 GHz RF System on Chip
Pages / Page115 / 103 — 11.7. CEAA WLCSP package. 11.7.1. CEAA WLCSP schematic with internal LDO …
File Format / SizePDF / 7.1 Mb
11.7. CEAA WLCSP package. 11.7.1. CEAA WLCSP schematic with internal LDO setup. nRF51x22. Figure 34. Note:
11.7 CEAA WLCSP package 11.7.1 CEAA WLCSP schematic with internal LDO setup nRF51x22 Figure 34 Note:
nRF51822 Product Specification v3.1
Documentation for the CEAA WLCSP package reference circuit, including Altium Designer files, PCB layout files, and PCB production files, can be downloaded from www.nordicsemi.com.
C1 Optional C13 12pF X1 12pF 16MHz X2 C2 C14 32.768kHz 12pF 12pF C8 100nF 9 8 5 4 3 2 1 2 2 1 2 2 2 2 2 2 VCC_nRF P0. P0. XL XL P0. P0. P0. P0. P0. C7 B7 A8 A7 C5 A6 B6 B5 A5 A4 A3 A2 C9 1.0nF VCC_nRF 9 8 7 6 5 4 3 2 1 2 2 2 2 2 2 2 2 2 B8 VDD XC2 XC1 P0. P0. P0. P0. P0. P0. P0. P0. P0. B9 DEC1 A1 DCC AVDD P0.30 D8 G6 P0.30 VSS P0.31 E8 G9 C7 P0.31 VSS P0.00 C9 D7 B1 100nF P0.00 VSS P0.01 E9 C1 B3 A1 RF P0.01 ANT2 ANT2 SE P0.02 D9 D1 A3 P0.02 ANT1 ANT1 P0.03 F9 E1 A2 B1 P0.03 VDD_PA VDD_PA GND P0.04 F8 F1 P0.04 DEC2 P0.05 H9 G1 P0.20 BAL-NRF02D3 P0.05 P0.20 P0.06 G8
nRF51x22
F2 P0.19 P0.06 P0.19 VCC_nRF P0.07 H7 H1 P0.18 P0.07 P0.18 H8 K G2 P0.17 VDD P0.17 O/nRESET C11 8 9 0 1 2 3 4 5 6 C10 C3 0 0 1 1 1 1 1 1 1 100nF 47nF 2.2nF VSS VSS P0. P0. P0. P0. P0. P0. P0. P0. P0. SWDI SWDCL VSS VSS U1 B1 B4 J8 J7 H6 J6 J5 H5 H4 J4 J3 J2 H2 C8 H3 nRF51x22-CEAA K O 8 9 0 1 2 3 4 5 6 0 0 1 1 1 1 1 1 1 P0. P0. P0. P0. P0. P0. P0. P0. P0. SWDI SWDCL
Figure 34
CEAA WLCSP with internal LDO setup
Note:
For PCB reference layouts, see the Reference Layout section on the Downloads tab for the different chip variants on www.nordicsemi.com. Page 103 Document Outline 1 Introduction 1.1 Required reading 1.2 Writing conventions 2 Product overview 2.1 Block diagram 2.2 Pin assignments and functions 2.2.1 Pin assignment QFN48 2.2.2 CDAB WLCSP ball assignment and functions 2.2.3 CEAA and CFAC WLCSP ball assignment and functions 3 System blocks 3.1 CPU 3.2 Memory 3.2.1 Code organization 3.2.2 RAM organization 3.3 Memory Protection Unit (MPU) 3.4 Power management (POWER) 3.4.1 Power supply 3.4.2 Power management 3.5 Programmable Peripheral Interconnect (PPI) 3.6 Clock management (CLOCK) 3.6.1 16/32 MHz crystal oscillator 3.6.2 32.768 kHz crystal oscillator 3.6.3 32.768 kHz RC oscillator 3.6.4 Synthesized 32.768 kHz clock 3.7 GPIO 3.8 Debugger support 4 Peripheral blocks 4.1 2.4 GHz radio (RADIO) 4.2 Timer/counters (TIMER) 4.3 Real Time Counter (RTC) 4.4 AES Electronic Codebook Mode Encryption (ECB) 4.5 AES CCM Mode Encryption (CCM) 4.6 Accelerated Address Resolver (AAR) 4.7 Random Number Generator (RNG) 4.8 Watchdog Timer (WDT) 4.9 Temperature sensor (TEMP) 4.10 Serial Peripheral Interface (SPI/SPIS) 4.11 Two-wire interface (TWI) 4.12 Universal Asynchronous Receiver/Transmitter (UART) 4.13 Quadrature Decoder (QDEC) 4.14 Analog to Digital Converter (ADC) 4.15 GPIO Task Event blocks (GPIOTE) 4.16 Low Power Comparator (LPCOMP) 5 Instance table 6 Absolute maximum ratings 7 Operating conditions 7.1 WLCSP light sensitivity 8 Electrical specifications 8.1 Clock sources 8.1.1 16/32 MHz crystal startup 8.1.2 16 MHz crystal oscillator (16M XOSC) 8.1.3 32 MHz crystal oscillator (32M XOSC) 8.1.4 16 MHz RC oscillator (16M RCOSC) 8.1.5 32.768 kHz crystal oscillator (32k XOSC) 8.1.6 32.768 kHz RC oscillator (32k RCOSC) 8.1.7 32.768 kHz Synthesized oscillator (32k SYNT) 8.2 Power management 8.3 Block resource requirements 8.4 CPU 8.5 Radio transceiver 8.5.1 General radio characteristics 8.5.2 Radio current consumption with DC/DC disabled 8.5.3 Radio current consumption with DC/DC enabled 8.5.4 Transmitter specifications 8.5.5 Receiver specifications 8.5.6 Radio timing parameters 8.5.7 Antenna matching network requirements 8.6 Received Signal Strength Indicator (RSSI) specifications 8.7 Universal Asynchronous Receiver/Transmitter (UART) specifications 8.8 Serial Peripheral Interface Slave (SPIS) specifications 8.9 Serial Peripheral Interface (SPI) Master specifications 8.10 I2C compatible Two Wire Interface (TWI) specifications 8.11 GPIO Tasks and Events (GPIOTE) specifications 8.12 Analog to Digital Converter (ADC) specifications 8.13 Timer (TIMER) specifications 8.14 Real Time Counter (RTC) 8.15 Temperature sensor (TEMP) 8.16 Random Number Generator (RNG) specifications 8.17 AES Electronic Codebook Mode Encryption (ECB) specifications 8.18 AES CCM Mode Encryption (CCM) specifications 8.19 Accelerated Address Resolver (AAR) specifications 8.20 Watchdog Timer (WDT) specifications 8.21 Quadrature Decoder (QDEC) specifications 8.22 Non-Volatile Memory Controller (NVMC) specifications 8.23 General Purpose I/O (GPIO) specifications 8.24 Low Power Comparator (LPCOMP) specifications 9 Mechanical specifications 9.1 QFN48 package 9.2 CDAB WLCSP package 9.3 CEAA WLCSP package 9.4 CFAC WLCSP package 10 Ordering information 10.1 Chip marking 10.2 Inner box label 10.3 Outer box label 10.4 Order code 10.5 Abbreviations 10.6 Code ranges and values 10.7 Product options 10.7.1 nRF ICs 10.7.2 Development tools 11 Reference circuitry 11.1 PCB guidelines 11.1.1 PCB layout example 11.2 Reference design schematics 11.3 QFAA QFN48 package 11.3.1 QFAA QFN48 schematic with internal LDO setup 11.3.2 QFAA QFN48 schematic with low voltage mode setup 11.3.3 QFAA QFN48 schematic with DC/DC converter setup 11.4 QFAB QFN48 package 11.4.1 QFAB QFN48 schematic with internal LDO setup 11.4.2 QFAB QFN48 schematic with low voltage mode setup 11.4.3 QFAB QFN48 schematic with DC/DC converter setup 11.5 QFAC QFN48 package 11.5.1 QFAC QFN48 schematic with internal LDO setup 11.5.2 QFAC QFN48 schematic with low voltage mode setup 11.5.3 QFAC QFN48 schematic with DC/DC converter setup 11.6 CDAB WLCSP package 11.6.1 CDAB WLCSP schematic with internal LDO setup 11.6.2 CDAB WLCSP schematic with low voltage mode setup 11.6.3 CDAB WLCSP schematic with DC/DC converter setup 11.7 CEAA WLCSP package 11.7.1 CEAA WLCSP schematic with internal LDO setup 11.7.2 CEAA WLCSP schematic with low voltage mode setup 11.7.3 CEAA WLCSP schematic with DC/DC converter setup 11.8 CFAC WLCSP package 11.8.1 CFAC WLCSP schematic with internal LDO setup 11.8.2 CFAC WLCSP schematic with low voltage mode setup 11.8.3 CFAC WLCSP schematic with DC/DC converter setup 12 Glossary
