Datasheet LTC6943 (Analog Devices) - 16
Description | Micropower, Dual Precision Instrumentation Switched Capacitor Building Block |
Pages / Page | 16 / 16 — TYPICAL APPLICATIO S. 5V Powered Voltage-to-Frequency Converter. RELATED … |
File Format / Size | PDF / 250 Kb |
TYPICAL APPLICATIO S. 5V Powered Voltage-to-Frequency Converter. RELATED PARTS. PART NUMBER. DESCRIPTION. COMMENTS
LTC6943
U TYPICAL APPLICATIO S 5V Powered Voltage-to-Frequency Converter
5VIN 2 fOUT 0kHz TO 16 13 3kHz LTC6943 3 15 22k 5 4 1 + C1** LT1034 22µF 0.01 1.2V µF 2 16 13 14 10k FULL SCALE 5VIN TRIM 75k* D1 C2 INPUT – 1N4148 560pF 0V TO 1µF A1 2V 1/2 LT1017 + 120pF 1N5712 50k 1.6M (10Hz TRIM) 6943 TA19 10k * = 1% FILM RESISTOR, TYPE TRW-MTR+120ppm/°C ** = POLYPROPYLENE
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC1043 Dual Precision Instrumentation 120dB CMRR, 3V to 18V Operation Switched Cap, Building Block LTC1152 Rail-to-Rail In/Out, Zero Drift Op Amp Operates Up to 14V Supply Voltage LTC2050 Zero Drift Op Amp Single Supply Operation on 2.7V to 11V, SOT-23 Package LTC2051 Zero Drift Dual Op Amp Dual LTC2050, 8-Lead DFN, MS8 Packages LTC2052 Zero Drift Quad Op Amp Dual LTC2050, GN16 Package LTC2053 Precision, Rail-to-Rail Zero Drift I.A. 120dB CMRR at Low Gains LTC2054 Low Power, Zero Drift Op Amp 150µA Supply Current, SOT-23 Package LTC6800 Low Cost, Rail-to-Rail I.A. VOS(MAX) = 100µV, DFN 8 Package LTC6915 Precision Instrumentation Amplifier 14 Levels of Programmable Gain, 125dB CMRR with Digitally Programmable Gain 6943f LT/TP 0804 1K • PRINTED IN USA 16 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com © LINEAR TECHNOLOGY CORPORATION 2004
