Datasheet MPU-6000, MPU-6050 - 12 Description MPU-60X0 is the world's first integrated 6-axis MotionTracking device that combines a 3-axis gyroscope, 3-axis accelerometer, and a Digital Motion ProcessorTM (DMP) all in a small 4x4x0.9mm package Pages / Page 52 / 12 — MPU-6000/MPU-6050 Product Specification. Electrical Characteristics. 6.1. … Revision 3.4 File Format / Size PDF / 1.6 Mb Document Language English
MPU-6000/MPU-6050 Product Specification. Electrical Characteristics. 6.1. Gyroscope Specifications. PARAMETER. CONDITIONS. MIN. TYP
Model Line for this Datasheet Text Version of Document Document Number: PS-MPU-6000A-00MPU-6000/MPU-6050 Product Specification Revision: 3.4 Release Date: 08/19/20136 Electrical Characteristics 6.1 Gyroscope Specifications VDD = 2.375V-3.46V, VLOGIC (MPU-6050 only) = 1.8V±5% or VDD, TA = 25°CPARAMETER CONDITIONS MIN TYP MAX UNITS NOTES GYROSCOPE SENSITIVITY Full-Scale Range FS_SEL=0 ±250 º/s FS_SEL=1 ±500 º/s FS_SEL=2 ±1000 º/s FS_SEL=3 ±2000 º/s Gyroscope ADC Word Length 16 bits Sensitivity Scale Factor FS_SEL=0 131 LSB/(º/s) FS_SEL=1 65.5 LSB/(º/s) FS_SEL=2 32.8 LSB/(º/s) FS_SEL=3 16.4 LSB/(º/s) Sensitivity Scale Factor Tolerance 25°C -3 +3 % Sensitivity Scale Factor Variation Over ±2 % Temperature Nonlinearity Best fit straight line; 25°C 0.2 % Cross-Axis Sensitivity ±2 %GYROSCOPE ZERO-RATE OUTPUT (ZRO) Initial ZRO Tolerance 25°C ±20 º/s ZRO Variation Over Temperature -40°C to +85°C ±20 º/s Power-Supply Sensitivity (1-10Hz) Sine wave, 100mVpp; VDD=2.5V 0.2 º/s Power-Supply Sensitivity (10 - 250Hz) Sine wave, 100mVpp; VDD=2.5V 0.2 º/s Power-Supply Sensitivity (250Hz - 100kHz) Sine wave, 100mVpp; VDD=2.5V 4 º/s Linear Acceleration Sensitivity Static 0.1 º/s/gSELF-TEST RESPONSE Relative Change from factory trim -14 14 % 1GYROSCOPE NOISE PERFORMANCE FS_SEL=0 Total RMS Noise DLPFCFG=2 (100Hz) 0.05 º/s-rms Low-frequency RMS noise Bandwidth 1Hz to10Hz 0.033 º/s-rms Rate Noise Spectral Density At 10Hz 0.005 º/s/√HzGYROSCOPE MECHANICAL FREQUENCIES X-Axis 30 33 36 kHz Y-Axis 27 30 33 kHz Z-Axis 24 27 30 kHzLOW PASS FILTER RESPONSE Programmable Range 5 256 HzOUTPUT DATA RATE Programmable 4 8,000 HzGYROSCOPE START-UP TIME DLPFCFG=0 ZRO Settling (from power-on) to ±1º/s of Final 30 ms 1. Please refer to the following document for further information on Self-Test: MPU-6000/MPU-6050 Register Map and Descriptions 12 of 52
