Datasheet LT1011, LT1011A (Analog Devices) - 15
| Description | Voltage Comparator |
| Pages / Page | 20 / 15 — Typical applicaTions. Fast Settling Filter. 100kHz Precision Rectifier |
| File Format / Size | PDF / 296 Kb |
LT1011/LT1011A
Typical applicaTions Fast Settling Filter
100pF 1M 15V 2 7 1M 6 LT1008C OUTPUT 4.7k 3 8 VIN 1 4.7k 4 1µF –15V 15V OFM-1A 0.1µF –15V 100pF 100k 4 2 – 8 1.5k 7 1 LT1011 3 + 5 6 INPUT* 15V 15V COMPARATORS DRIVE OPTO-COUPLED FET 5k 5k “ON” WHEN DIFFERENCE BETWEEN OUTPUT THRESHOLD AND INPUT EXCEEDS THRESHOLD. WHEN 6 OUTPUT APPROACHES INPUT, THE GATE TURNS 3 “OFF” AND LOW PASS FILTERING OCCURS. + 5 1 *INPUT POLARITY IS REVERSED WHEN USING LT1011 PIN 1 AS OUTPUT 2 – 7 8 4 10k –15V 15V 1011 TA21
0.033µF 5V 5V 5V 100Ω 2 AC INPUT + 5V 8 1k 12k 5k 7 74C04 820Ω ZERO LT1011 CROSS 3 HP5082-2800 TRIM – 1 –5V ×4 4 RECTIFIED OUTPUT 5V –5V 820Ω 1k 74C04 12k –5V –5V 1011 TA23 1011afe For more information www.linear.com/LT1011 15 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Typical Applications Schematic Diagram Package Description Revision History Typical Application Related Parts
