Datasheet LT1534 (Analog Devices) - 16
DescriptionUltralow Noise 2A Switching Regulators
Pages / Page16 / 16 — TYPICAL APPLICATION. Low Noise Wide Input Range. 5V Supply. RELATED …
File Format / SizePDF / 216 Kb
TYPICAL APPLICATION. Low Noise Wide Input Range. 5V Supply. RELATED PARTS. PART NUMBER. DESCRIPTION. COMMENTS
TYPICAL APPLICATION Low Noise Wide Input Range 5V Supply RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT1534/LT1534-1
U TYPICAL APPLICATION Low Noise Wide Input Range
5V Supply
C2 10µF 16V 1N5817 V V + IN OUT1 3V TO 12V 5V + T1 C1 1 6 150mA* 10µF 16V + C4 4 3 47µF 2 12 6.3V 15 5 9 VIN 4 2 SYNC COL + 12 10Ω 11 C3 1N5817 SHDN L2 28nH 10µF 1nF T1 10 LT1534-1 3 16V NFB PGND + C5 8 47µF 10 6.3V 11 7.5k 7 T1 V FB V C OUT1 R C GND R R T T VSL CSL 7 V 6.8k 2.49k OUT2 – 5V 6 5 1,8 14 13 0.01µF 150mA* 9,16 *TOTAL OUTPUT CURRENT ≤ 300mA 4k TO 4k TO 220pF 16.9k 1500pF C1, C2, C3: MATSUSHITA ECGCICB6R8 25k 25k C4, C5: MATSUSHITA ECGC0JB470 L2: COILCRAFT B08T OR PC TRACE T1: COILTRONICS VP2-0216 1534 TA03
LT1129 700mA Micropower Low Dropout Regulator 0.4V Dropout Voltage, Reverse Battery Protection LT1175 500mA Negative Low Dropout Micropower Regulator Positive or Negative Shutdown Logic LT1370 500kHz High Efficiency 6A Switching Regulator 90% Efficiency, Constant Frequency, High Power LT1371 500kHz High Efficiency 3A Switching Regulator 90% Efficiency, Constant Frequency, Synchronizable LT1377 1MHz High Efficiency 1.5A Switching Regulator High Frequency, Small Inductor LT1425 Isolated Flyback Switching Regulator Excellent Regulation Without Transformer “Third Winding” LT1533 Ultralow Noise 1A Switching Regulator Push-Pull Design for Low Noise Isolated Supplies LT1763 500mA Low Noise Micropower LDO 20µVRMS(10Hz to 100kHz), 30µA Quiescent Current LT1777 700mA Low Noise Step-Down Switching Regulator Programmable dI/dt Limit, 48VMax VIN 1534fa LT/TP 0300 2K REV A • PRINTED IN USA 16 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 LINEAR TECHNOLOGY CORPORATION 1998 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear-tech.com
