Datasheet LTC3588-2 (Analog Devices) - 18
DescriptionNanopower Energy Harvesting Power Supply with 14V Minimum VIN
Pages / Page18 / 18 — TYPICAL APPLICATION. Piezoelectric Shunt Charger for Small Li-Ion Cells …
File Format / SizePDF / 434 Kb
TYPICAL APPLICATION. Piezoelectric Shunt Charger for Small Li-Ion Cells or Thin Film Batteries
TYPICAL APPLICATION Piezoelectric Shunt Charger for Small Li-Ion Cells or Thin Film Batteries
LTC3588-2
ADVANCED CERAMETRICS PFCB-W14 V PZ1 PZ2 OUT 22µH 5.0V 8.87k 100µA CONTINUOUS VIN SW 20mA PULSED 1µF V LTC3588-2 OUT 6.3V V DMP2104LP CAP CC 22µF NTCBIAS ADJ 25V C V OUT IN2 47µF 10k LTC4070 NC7SVL04 D1 PGOOD 6.3V 4.7µF NTC LBO INFINITE POWER SOLUTIONS D0 6.3V + MEC101-10SES GND GND T* 4.7M Li-ION 4.1V 1mAh 35882 TA02 * NTHS0805E3103LT LOCATE NEAR BATTERY
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT1389 Nanopower Precision Shunt Voltage Reference 800nA Operating Current, 1.25V/2.5V/4.096V LTC1540 Nanopower Comparator with Reference 0.3µA IQ, Drives 0.01µF, Adjustable Hysteresis, 2V to 11V Input Range LT3009 3µA IQ, 20mA Low Dropout Linear Regulator Low 3µA IQ, 1.6V to 20V Range, 20mA Output Current LTC3105 400mA Step-Up Converter with 250mV Start-Up and High Efficiency Step-Up DC/DC Converter, VIN: 0.225V to 5V, Integrated Maximum Power Point Control Maximum Power Point Controller (MPPT), Photovoltaic Cells, Thermoelectric Generators (TEGs), and Fuel Cells, Burst Mode® Operation LTC3108/ Ultralow Voltage Step-Up Converter and Power Manager VIN: 0.02V to 1V, VOUT = 2.2V, 2.35V, 3.3V, 4.1V, 5V, IQ = 6µA, 4mm × LTC3108-1 3mm DFN-12, SSOP-16 Packages, LTC3108-1 VOUT = 2.2V, 2.5V, 3V, 3.7V, 4.5V LTC3109 Auto-Polarity, Ultralow Voltage Step-Up Converter and Power |VIN|: 0.03V to 1V, VOUT = 2.2V, 2.35V, 3.3V, 4.1V, 5V, IQ = 7µA, Manager 4mm × 4mm QFN-20, SSOP-20 Packages LTC3388-1/ 20V High Efficiency Nanopower Step-Down Regulator 860nA IQ in Sleep, 2.7V to 20V Input, VOUT: 1.2V to 5V, LTC3388-3 Enable and Standby Pins LTC3588-1 Nanopower Energy Harvesting Power Supply 950nA IQ in Sleep, VOUT: 1.8V, 2.5V, 3.3V, 3.6V, Integrated Bridge Rectifier LTC3631 45V, 100mA, Synchronous Step-Down Regulator with 12µA IQ 4.5V to 45V Operating Range, Overvoltage Lockout Up to 60V LTC3642 45V, 50mA, Synchronous Step-Down Regulator with 12µA IQ 4.5V to 45V Operating Range, Overvoltage Lockout Up to 60V LT3652 Power Tracking 2A Battery Charger for Solar Power MPPT for Solar Applications, VIN: 4.95V to 32V, Charge Rate Up to 2A, User Selectable Termination: C/10 or On-Board Timer, Resister Programmable Float Voltage up to 14.4V, 3mm × 3mm DFN12 or MSOP-12 LT3970 40V, 350mA Step-Down Regulator with 2.5µA IQ Integrated Boost and Catch Diodes, 4.2V to 40V Operating Range LT3971 38V, 1.2A, 2MHz Step-Down Regulator with 2.8µA IQ 4.3V to 38V Operating Range, Low Ripple Burst Mode Operation LT3991 55V, 1.2A 2MHz Step-Down Regulator with 2.8µA IQ 4.3V to 55V Operating Range, Low Ripple Burst Mode Operation LTC4070 Li-Ion/Polymer Shunt Battery Charger System 450nA IQ, 1% Float Voltage Accuracy, 50mA Shunt Current 4V/4.1V/4.2V LTC4071 Li-Ion/Polymer Shunt Battery Charger System with Low 550nA IQ, 1% Float Voltage Accuracy, <10nA Low Battery Disconnect, Battery Disconnect 4V/4.1V/4.2V, 8-Lead 2mm × 3mm DFN and MSOP Packages LTC3330 Nanopower Buck-Boost DC/DC with Energy Harvesting VIN: 2.7V to 20V, BAT: 1.8V to 5.5V, 750nA IQ, 5mm × 5mm Battery Life Extender QFN-32 Package LTC3331 Nanopower Buck-Boost DC/DC with Energy Harvesting VIN: 2.7V to 20V, BAT: Up to 4.2V, Shunt Charger, Low Battery Battery Charger Disconnect, 950nA IQ, 5mm × 5mm QFN-32 Package 35882fc 18 LT 0815 REV C • PRINTED IN USA Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 9 F5or 0 m 35 o-r7e 4info 17 rmation www.linear.com/LTC3588-2 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com/LTC3588-2 LINEAR TECHNOLOGY CORPORATION 2010 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Revision History Typical Application Related Parts
