Datasheet ADXRS453 (Analog Devices) - 28
DescriptionHigh Performance, Digital Output Gyroscope
Pages / Page33 / 28 — Data Sheet. ADXRS453. PACKAGE MARKING CODES. XRS453. BEYZ n. BRGZ n. …
File Format / SizePDF / 833 Kb
Data Sheet. ADXRS453. PACKAGE MARKING CODES. XRS453. BEYZ n. BRGZ n. #YYWW. LLLLLLLLL
Data Sheet ADXRS453 PACKAGE MARKING CODES XRS453 BEYZ n BRGZ n #YYWW LLLLLLLLL
Data Sheet ADXRS453 PACKAGE MARKING CODES XRS453 XRS453 BEYZ n BRGZ n #YYWW #YYWW LLLLLLLLL LLLLLLLLL
-038 155 09 Figure 36. LCC_V and SOIC_CAV Package Marking Codes
Table 19. Package Code Designations Marking Meaning
XRS Angular rate sensor 453 Series number B Temperature grade (−40°C to +105°C) RG Package designator (SOIC_CAV package) EY Package designator (LCC_V package) Z RoHS compliant n Revision number # Pb-free designation YYWW Assembly date code LLLLLLLLL Assembly lot code (up to nine characters) Rev. B | Page 27 of 32 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Thermal Resistance Rate Sensitive Axis ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Continuous Self-Test Mechanical Performance Noise Performance Applications Information Calibrated Performance Mechanical Considerations for Mounting Application Circuits ADXRS453 Signal Chain Timing SPI Communication Protocol Command/Response Device Data Latching SPI Timing Characteristics Command/Response Bit Definitions SQ2 to SQ0 Bits SM2 to SM0 Bits A8 to A0 Bits D15 to D0 Bits P Bit SPI Bit RE Bit DU Bit ST1 and ST0 Bits P0 Bit P1 Bit Fault Register Bit Definitions Fail Bit AMP Bit OV Bit UV Bit PLL Bit Q Bit NVM Bit POR Bit PWR Bit CST Bit CHK Bit Recommended Start-Up Sequence with CHK Bit Assertion Rate Data Format Memory Map and Registers Memory Map Memory Register Definitions Rate (RATEx) Registers Temperature (TEMx) Registers Low CST (LOCSTx) Registers High CST (HICSTx) Registers Quad Memory (QUADx) Registers Fault (FAULTx) Registers Part ID (PIDx) Registers Serial Number (SNx) Registers Package Orientation and Layout Information Solder Profile Package Marking Codes Outline Dimensions Ordering Guide
