link to page 16 link to page 8 ADIS16080APPLICATIONS INFORMATION ASSEMBLY The ADIS16080 is a system-in-package (SIP) that integrates ADIS1608012 ST2 multiple components in a land grid array (LGA). This 6FILTJ12J212SCLK configuration offers the convenience of solder-reflow C31216 CS1µF3 installation on printed circuit boards (PCBs). When developing 34DOUT53413RATE a process flow for installing ADIS16080 devices on PCBs, see ST1156DIN4 JEDEC standard document, J-STD-020C, for reflow temper- 56NC15 ature profile and processing information. The ADIS16080 can NC7878 use either the Sn-PB eutectic process or the Pb-free eutectic 10GND8 process from this standard. See JEDEC J-STD-033 for moisture 910AIN1910149VAIN2CC sensitivity (MSL) handling requirements. The MSL rating for 7111112VDRIVE V1112REF these devices is marked on the antistatic bags, which protect these devices from ESD during shipping and handling. Prior to C1C4C2 8 1µF1µF1µF 1 -1 assembly, review the process flow for information about 045 06 introducing shock levels that exceed the ADIS16080’s absolute Figure 23. Electrical Schematic maximum ratings. Some PCB separation and ultrasonic cleaning processes are common areas that can introduce high levels of shock to these devices. 100 1.INTERFACE BOARD1.050 The ADIS16080/PCBZ (see the Ordering Guide) provides the 2 × 0.925 a ADIS16080 functionality on a 1.2 inch × 1.3 inch printed circuit J1J2 board, which simplifies the connection to an existing processor U12 × 0.673 system. The four mounting holes accommodate either M2 (2 mm) iSensor or 2-56 machine screws. These boards are made of IS410 material and are 0.063 inches thick. The second level assembly uses a SAC305-compatible solder composition, which has a presolder 4 × Ø0.087C1M2×0.4 reflow thickness of approximately 0.005 inches. The pad pattern on the ADIS16080/PCBZ matches Figure 5. J1 and J2 are dual- 2 × 0.000 row, 2 mm (pitch) connectors that work with several ribbon 0.150 cable systems, including 3M Part Number 152212-0100-GB (ribbon-crimp connector) and 3M Part Number 3625/12 (ribbon cable). 200035000865900 7 1 0.0.0.0.0. -1 45 ××22 60 0 Figure 24. PCB Assembly View and Dimensions Rev. $ | Page 14 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SUPPLY AND COMMON CONSIDERATIONS INCREASING MEASUREMENT RANGE SETTING BANDWIDTH SELF-TEST FUNCTION CONTINUOUS SELF-TEST RATE SENSITIVE AXIS BASIC OPERATION SERIAL PERIPHERAL INTERFACE (SPI) Control Register ADC Conversion Output Data Access Output Coding Examples APPLICATIONS INFORMATION ASSEMBLY INTERFACE BOARD OUTLINE DIMENSIONS ORDERING GUIDE
