Datasheet ADIS16080 (Analog Devices) - 16
Description | ±80°/sec Yaw Rate Gyro with SPI Interface |
Pages / Page | 17 / 16 — ADIS16080. OUTLINE DIMENSIONS. 5.010. BSC. 2.505. PIN 1. INDICATOR. 8.35. … |
Revision | C |
File Format / Size | PDF / 579 Kb |
ADIS16080. OUTLINE DIMENSIONS. 5.010. BSC. 2.505. PIN 1. INDICATOR. 8.35. MAX. 0.873 BSC (16. 7.373. 8.20. TYP. 0.797 BSC (12. TOP VIEW. 0.200
link to page 16 link to page 16
ADIS16080 OUTLINE DIMENSIONS 5.010 BSC (4
) 2.505 PIN 1 BSC INDICATOR 8.35 (8
) MAX 0.873 BSC (16
) 13 16 12 1 7.373 8.20 BSC TYP (2
0.797 BSC (12
) 9 4 8 5 TOP VIEW 0.200 BOTTOM VIEW 0.373 BSC MIN (16
) (ALL SIDES
7.00 TYP 5.20 MAX B 07- 21 SIDE VIEW 02
Figure 25. 16-Terminal Stacked Land Grid Array [LGA] (CC-16-1) Dimensions shown in millimeters
ORDERING GUIDE Model
1
Temperature Range Package Description Package Option
ADIS16080ACCZ −40°C to +85°C 16-Terminal Stacked Land Grid Array (LGA) CC-16-1 ADIS16080/PCBZ Evaluation Board 1 Z = RoHS Compliant Part. Rev. C | Page 15 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SUPPLY AND COMMON CONSIDERATIONS INCREASING MEASUREMENT RANGE SETTING BANDWIDTH SELF-TEST FUNCTION CONTINUOUS SELF-TEST RATE SENSITIVE AXIS BASIC OPERATION SERIAL PERIPHERAL INTERFACE (SPI) Control Register ADC Conversion Output Data Access Output Coding Examples APPLICATIONS INFORMATION ASSEMBLY INTERFACE BOARD OUTLINE DIMENSIONS ORDERING GUIDE
