Datasheet PIC16F631, PIC16F677, PIC16F685, PIC16F687, PIC16F689, PIC16F690 (Microchip) - 16
ManufacturerMicrochip
Description20-Pin Flash-Based, 8-Bit CMOS Microcontrollers
Pages / Page298 / 16 — PIC16F631/677/685/687/689/690. TABLE 1-2: PINOUT DESCRIPTION – PIC16F677 …
File Format / SizePDF / 3.1 Mb
PIC16F631/677/685/687/689/690. TABLE 1-2: PINOUT DESCRIPTION – PIC16F677 Name. RA0/AN0/C1IN+/ICSPDAT/
PIC16F631/677/685/687/689/690 TABLE 1-2: PINOUT DESCRIPTION – PIC16F677 Name RA0/AN0/C1IN+/ICSPDAT/
PIC16F631
PIC16F677
PIC16F685
PIC16F687
PIC16F689
PIC16F690
ULPWU RA1/AN1/C12IN0-/VREF/
ICSPCLK RA2/AN2/T0CKI/INT/C1OUT RA3/MCLR/VPP RA4/AN3/T1G/OSC2/CLKOUT RA5/T1CKI/OSC1/CLKIN RB4/AN10/SDI/SDA RB5/AN11 RB6/SCK/SCL Legend: Function Input
Type RA0 TTL Description CMOS General purpose I/O. Individually controlled interrupt-on-change.
Individually enabled pull-up. AN0 AN — A/D Channel 0 input. C1IN+ AN — Comparator C1 non-inverting input. ICSPDAT ST ULPWU AN RA1 TTL CMOS ICSP™ Data I/O.
— Ultra Low-Power Wake-up input. CMOS General purpose I/O. Individually controlled interrupt-on-change.
Individually enabled pull-up. AN1 AN — A/D Channel 1 input. C12IN0-AN — Comparator C1 or C2 inverting input. VREF AN — External Voltage Reference for A/D. ICSPCLK ST — ICSP™ clock. RA2 ST AN2 AN — A/D Channel 2 input. T0CKI ST — Timer0 clock input. INT ST — External interrupt pin. C1OUT — RA3 TTL CMOS General purpose I/O. Individually controlled interrupt-on-change.
Individually enabled pull-up. CMOS Comparator C1 output.
— General purpose input. Individually controlled interrupt-onchange. MCLR ST — Master Clear with internal pull-up. VPP HV — Programming voltage. RA4 TTL AN3 AN T1G ST — Timer1 gate input. OSC2 — XTAL Crystal/Resonator. CLKOUT — RA5 TTL CMOS General purpose I/O. Individually controlled interrupt-on-change.
— A/D Channel 3 input. CMOS FOSC/4 output.
Individually enabled pull-up. T1CKI ST — Timer1 clock input. OSC1 XTAL — Crystal/Resonator. — External clock input/RC oscillator connection. CLKIN ST RB4 TTL AN10 AN — A/D Channel 10 input. SDI ST — SPI data input. SDA ST OD I2C™ data input/output. RB5 TTL CMOS General purpose I/O. Individually controlled interrupt-on-change.
Individually enabled pull-up. CMOS General purpose I/O. Individually controlled interrupt-on-change.
Individually enabled pull-up. AN11 AN RB6 TTL CMOS General purpose I/O. Individually controlled interrupt-on-change.
Individually enabled pull-up. SCK ST CMOS SPI clock. SCL ST AN = Analog input or output
TTL = TTL compatible input
HV = High Voltage DS40001262F-page 16 Output
Type — OD A/D Channel 11 input. I2C™ clock. CMOS=CMOS compatible input or output
ST=
Schmitt Trigger input with CMOS levels
XTAL= Crystal  2005-2015 Microchip Technology Inc.
