Datasheet LTC4009, LTC4009-1, LTC4009-2 (Analog Devices) - 25
DescriptionHigh Efficiency, Multi-Chemistry Battery Charger
Pages / Page28 / 25 — Figure 13. Kelvin Sensing of Charge Current
File Format / SizePDF / 365 Kb
Figure 13 Kelvin Sensing of Charge Current
LTC4009 LTC4009-1/LTC4009-2 applicaTions inForMaTion 10. If possible, place all the parts listed above on the same 12. For best current programming accuracy, provide a PCB layer. Kelvin connection from RSENSE to CSP and CSN. See 11. Copper fil s or pours are good for al power connections Figure 13 for an example. except as noted above in Rule 3. Copper planes on 13. It is important to minimize parasitic capacitance on multiple layers can also be used in parallel. This helps the CSP and CSN pins. The traces connecting these with thermal management and lowers trace inductance, pins to their respective resistors should be as short which further improves EMI performance. as possible. DIRECTION OF CHARGING CURRENT RSENSE 4009 F13 TO CSP TO CSN RIN RIN
4009fd Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Test Circuits Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Typical Application Related Parts
