Datasheet LT6205, LT6206, LT6207 (Analog Devices) - 18
Description | Quad Single Supply 3V, 100MHz Video Op Amps |
Pages / Page | 18 / 18 — TYPICAL APPLICATION. YPBPR to RGB Converter. RELATED PARTS PART NUMBER. … |
File Format / Size | PDF / 267 Kb |
TYPICAL APPLICATION. YPBPR to RGB Converter. RELATED PARTS PART NUMBER. DESCRIPTION. COMMENTS
LT6205/LT6206/LT6207
TYPICAL APPLICATION YPBPR to RGB Converter
5V 1μF 36Ω CMPD6001S FMMT3906 150Ω R 4.7k 4 165Ω 499Ω 150Ω 75Ω 1 16 2 15 499Ω – – 150Ω B 3 14 Y + + 107Ω 150Ω 75Ω 75Ω LT6207 5 12 80.6Ω + + 6 11 – – 499Ω 365Ω 499Ω 7 10 P 150Ω B 13 95.3Ω 174Ω 150Ω G P 75Ω R 1μF 133Ω F3dB z 40MHz R = Y + 1.4 • PR IS b 60mA B = Y + 1.8 • PB BLACK LEVELS z 0V –5V G = Y – 0.34 • PB – 0.71 • PR 620567 TA03
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT1253/LT1254 Low Cost Dual and Quad Video Amplifi ers –3dB Bandwidth = 90MHz, Current Feedback LT1395/LT1396/LT1397 Single Dual Quad 400MHz Current Feedback Amplifi ers 0.1dB Flatness to 100MHz, 80mA Output Drive LT1675 RGB Multiplexer with Current Feedback Amplifi ers –3dB Bandwidth = 250MHz, 100MHz Pixel Switching LT1809/LT1810 Single/Dual, 180MHz, Rail-to-Rail Input and Output Amplifi ers 350V/μs Slew Rate, Shutdown, Low Distortion –90dBc at 5MHz LT6550/LT6551 3.3V Triple and Quad Video Amplifi ers Internal Gain of 2, 110MHz –3dB Bandwidth, Input Common Modes to Ground LT6552 3.3V Single Supply Video Difference Amplifi er Differential or Single-Ended Gain Block, 600V/μs Slew Rate, Input Common Modes to Ground 620567fc 18 Linear Technology Corporation LT 0310 REV C • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com © LINEAR TECHNOLOGY CORPORATION 2003 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION TYPICAL APPLICATION PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
