Datasheet LTM8074 (Analog Devices) - 21
Description40VIN, 1.2A Silent Switcher µModule Regulator
Pages / Page22 / 21 — PACKAGE DESCRIPTION. BGA Package. 25-Lead (4mm. 4mm. 1.82mm). DIMENSIONS. …
File Format / SizePDF / 2.9 Mb
PACKAGE DESCRIPTION. BGA Package. 25-Lead (4mm. 4mm. 1.82mm). DIMENSIONS. SYMBOL. MIN. NOM. MAX. NOTES
PACKAGE DESCRIPTION BGA Package 25-Lead (4mm 4mm 1.82mm) DIMENSIONS SYMBOL MIN NOM MAX NOTES
LTM8074
4mm
1.82mm)
(Reference LTC DWG# 05-08-1566 Rev A) Z A1 ccc Z A Z DETAIL A SEE NOTES 6 A2 SEE NOTES 5 4 3 2 1 2× aaa Z 3 PIN 1 A b1 PIN 1 MOLD CORNER b B CAP 4 SUBSTRATE D F C H1 H2 D e E DETAIL B // bbb Z X b e Øb (25 PLACES) E Y G ddd M Z X Y DETAIL B PACKAGE TOP VIEW aaa Z eee M Z PACKAGE SIDE VIEW PACKAGE BOTTOM VIEW 2× NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M-1994 2. ALL DIMENSIONS ARE IN MILLIMETERS BALL DESIGNA 3 TION PER JEP95 DETAIL A 4 DETAILS OF PIN 1 IDENTIFIER ARE OPTIONAL, BUT MUST BE LOCATED WITHIN THE ZONE INDICATED.
DIMENSIONS
THE PIN 1 IDENTIFIER MAY BE EITHER A MOLD OR MARKED FEATURE
A 1.66 1.82 1.98 5. PRIMARY DATUM -Z- IS SEATING PLANE 1.30 0.65 0.000 0.65 1.30 A1 0.23 0.30 0.37 BALL HT 6 PACKAGE ROW AND COLUMN LABELING MAY VARY A2 1.43 1.52 1.61
AMONG µModule PRODUCTS. REVIEW EACH PACKAGE 0.35 ±0.025 Ø 25x 1.30 b 0.35 0.40 0.45 BALL DIMENSION LAYOUT CAREFULLY 0.65 b1 0.32 0.35 0.38 PAD DIMENSION D 4.00 0.000 E 4.00 0.65 e 0.65 F 2.60 1.30 G 2.60 H1 0.32 REF SUBSTRATE THK SUGGESTED PCB LAYOUT LTMXXXX H2 1.20 REF MOLD CAP HT TOP VIEW µModule aaa 0.15 COMPONENT PIN 1 bbb 0.20 ccc 0.10 ddd 0.15 TRAY PIN 1 BEVEL eee 0.08 PACKAGE IN TRAY LOADING ORIENTATION BGA 25 0718 REV A TOTAL NUMBER OF BALLS: 25 Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications For more information www.a subject to change without notice. No license is granted by implication or other nalog.com wise under any patent or patent rights of Analog Devices. 21 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Photo Package Description Typical Application Related Parts
