Datasheet Si8941/46/47 (Silicon Labs) - 15
ManufacturerSilicon Labs
DescriptionIsolated Delta-Sigma Modulator for Current Shunt Measurement
Pages / Page35 / 15 — Table 4.7. IEC 60664-1 (VDE 0884) Ratings. Specification. Parameter. Test …
Revision0.5
File Format / SizePDF / 542 Kb
Table 4.7. IEC 60664-1 (VDE 0884) Ratings. Specification. Parameter. Test Conditions. WB Stretched. SOIC-8
Table 4.7 IEC 60664-1 (VDE 0884) Ratings Specification Parameter Test Conditions WB Stretched SOIC-8
link to page 15 Si8941/46/47 Data Sheet Electrical Specifications
Table 4.7. IEC 60664-1 (VDE 0884) Ratings Specification Parameter Test Conditions WB Stretched SOIC-8
Basic Isolation Group Material Group I Rated Mains Voltages < 150 VRMS I-IV Installation Rated Mains Voltages < 300 VRMS I-IV Classification Rated Mains Voltages < 450 VRMS I-III Rated Mains Voltages < 600 VRMS I-III
Table 4.8. VDE 0884-10 Insulation Characteristics1 Characteristic Parameter Symbol Test Condition Unit WB Stretched SOIC-8
Maximum Working Insulation V Voltage IORM 1414 V peak Method b1 (VIORM x 1.875 = VPR, 100% Input to Output Test Voltage VPR 2650 V peak Production Test, tm = 1 sec, Partial Discharge < 5 pC) Transient Overvoltage VIOTM t = 60 sec 8000 V peak Pollution Degree 2 (DIN VDE 0110, Table 1) Insulation Resistance at TS, VIO R = 500 V S >109 Ω
Note:
1. This isolator is suitable for reinforced electrical isolation only within the safety limit data. Maintenance of the safety data is ensur- ed by protective circuits. The Si8941/46/47 provides a climate classification of 40/125/21.
silabs.com
| Building a more connected world. Preliminary Rev. 0.5 | 15 Document Outline 1. Ordering Guide 2. System Overview 2.1 Modulator 3. Current Sense Application 4. Electrical Specifications 4.1 Regulatory Information 4.2 Typical Operating Characteristics 5. Pin Descriptions 6. Packaging 6.1 Package Outline: 8-Pin Wide Body Stretched SOIC 6.2 Package Outline: 8-Pin Narrow Body SOIC 6.3 Land Pattern: 8-Pin Wide Body Stretched SOIC 6.4 Land Pattern: 8-Pin Narrow Body SOIC 6.5 Top Marking: 8-Pin Wide Body Stretched SOIC 6.6 Top Marking: 8-Pin Narrow Body SOIC 7. Revision History
