Datasheet GW1NRF (GOWIN Semiconductor) - 11
ManufacturerGOWIN Semiconductor
DescriptionSeries of Bluetooth FPGA Products
Pages / Page86 / 11 — 1.4 Abbreviations and Terminology. Table 1-1 Abbreviations and …
1.4 Abbreviations and Terminology. Table 1-1 Abbreviations and Terminologies
1.4 Abbreviations and Terminology Table 1-1 Abbreviations and Terminologies
link to page 11 1About This Guide 1.4Abbreviations and Terminology
The abbreviations and terminology used in this manual are set out in Table 1-1 below.
Abbreviations and Terminology Name FPGA Field Programmable Gate Array SIP System in Package SOC System on Chip RF Radio Freqency OTP One Time Programmable HCI Host Controller Interface ACI Application Controller Interface ROM Read Only Memory SDRAM Synchronous Dynamic RAM PSRAM Pseudo Static Random Access Memory CFU Configurable Function Unit CLS Configurable Logic Slice CRU Configurable Routing Unit LUT4 4-input Look-up Tables LUT5 5-input Look-up Tables LUT6 6-input Look-up Tables LUT7 7-input Look-up Tables LUT8 8-input Look-up Tables REG Register ALU Arithmetic Logic Unit IOB Input/Output Block S-SRAM Shadow SRAM B-SRAM Block SRAM SP Single Port SDP Semi Dual Port DP Dual Port DSP Digital Signal Processing DQCE Dynamic Quadrant Clock Enable DCS Dynamic Clock Selector PLL Phase-locked Loop DLL Delay-locked Loop QN88 QFN88 TDM Time Division Multiplexing DS891-1.0E 2(76) Document Outline Disclaimer Revision History Contents List of Figures List of Tables 1 About This Guide 1.1 Purpose 1.2 Supported Products 1.3 Related Documents 1.4 Abbreviations and Terminology 1.5 Support and Feedback 2 General Description 2.1 Features 2.2 Product Resources 2.3 Package Information 3 Architecture 3.1 Architecture Overview 3.2 SoC System FPU Memories Security Peripherals 3.2.1 Bluetooth Module Bluetooth Controller Mode Bluetooth Companion Mode Bluetooth Application Mode 3.2.2 Timers 3.2.3 Power Management DC DC Switching Power Supply Supply Monitoring 3.2.4 RF Description 3.2.5 Operating Modes 3.2.6 Software Development 3.3 Configurable Function Unit 3.3.1 CLU Register 3.3.2 CRU 3.4 IOB 3.4.1 I/O Buffer 3.4.2 True LVDS Design 3.4.3 I/O Logic IODELAY I/O Register IEM De-serializer DES and Clock Domain Transfer Serializer SER 3.4.4 I/O Logic Modes Basic Mode SDR Mode Generic DDR Mode IDES4 OSER4 Mode IVideo Mode OVideo Mode IDES8 Mode OSER8 Mode IDES10 Mode OSER10 Mode 3.5 Block SRAM (B-SRAM) 3.5.1 Introduction 3.5.2 Configuration Mode 3.5.3 Mixed Data Bus Width Configuration 3.5.4 Byte-enable 3.5.5 Parity Bit 3.5.6 Synchronous operation 3.5.7 Power up Conditions 3.5.8 Operation Modes Single Port Mode Dual Port Mode Semi-Dual Port Mode Read Only 3.5.9 B-SRAM Operation Modes Read Mode Pipeline Mode Bypass Mode Write Mode 3.5.10 Clock Operations Independent Clock Mode Read/Write Clock Operation Single Port Clock Mode 3.6 User Flash 3.6.1 Introduction 3.6.2 User Flash Ports 3.6.3 User Flash Mode Truth Table User Modes 3.7 DSP 3.7.1 Introduction Macro PADD MULT ALU 3.7.2 DSP Operations 3.8 Clock 3.8.1 Global Clock 3.8.2 PLL 3.8.3 HCLK 3.8.4 DLL 3.9 Long Wire (LW) 3.10 Global Set/Reset (GSR) 3.11 Programming Configuration 3.11.1 SRAM Configuration 3.11.2 Flash Configuration 3.12 On Chip Oscillator 4 AC/DC Characteristics 4.1 Operating Conditions 4.2 ESD 4.3 DC Characteristics 4.3.1 Static Current 4.3.2 RF Parameters 4.3.3 I/O Characteristics 4.4 Switching Characteristics 4.4.1 Internal Switching Characteristics 4.4.2 External Switching Characteristics 4.5 User Flash Characteristics 4.5.1 DC Characteristics1 4.5.2 Timing Parameters1,5,6 4.5.3 Operation Timing Diagrams 4.6 Configuration Interface Timing Specification 4.6.1 JTAG Port Timing Specifications 4.6.2 AUTO BOOT Port Timing Specifications 4.6.3 SSPI Port Timing Specifications 4.6.4 MSPI Port Timing Specifications 4.6.5 DUAL BOOT 4.6.6 CPU 4.6.7 SERIAL 5 Ordering Information 5.1 Part Name 5.2 Package Mark
