Datasheet AOZ6683CI (Alpha & Omega) - 13
ManufacturerAlpha & Omega
DescriptionEZBuck 3A Synchronous Buck Regulator
Pages / Page15 / 13 — AOZ6683CI. Package Dimensions, TSOT23-6L. www.aosmd.com
File Format / SizePDF / 631 Kb
AOZ6683CI Package Dimensions, TSOT23-6L www.aosmd.com
GAUGE PLANE SEATING PLANE 6 5 4 1 2 3 B B b b1 c1 c BASE METAL WITH PLATING SECTION B-B RECOMMENDED LAND PATTERN DIMENSIONS IN MILLIMETERS DIMENSIONS IN INCHES SYMBOLS MIN NOM MAX MIN NOM MAX A --- --- 0.95 ---- ---- 0.037 A1 0.00 --- 0.10 0.000 ---- 0.004 A2 0.75 0.80 0.85 0.030 0.031 0.033 A3 0.35 0.40 0.45 0.014 0.016 0.018 b 0.30 0.44 0.50 0.012 0.017 0.020 b1 0.30 0.40 0.45 0.012 0.016 0.018 c 0.11 0.16 0.20 0.004 0.006 0.008 c1 0.11 0.13 0.15 0.004 0.005 0.006 D 2.70 2.90 3.10 0.106 0.114 0.122 E 2.60 2.80 3.00 0.102 0.110 0.118 E1 1.50 1.60 1.70 0.059 0.063 0.067 e 0.95 BSC 0.037BSC L 0.30 0.40 0.50 0.012 0.016 0.020 UNIT: mm 0 --- 8 0 ---- 8 NOTE 1. PACKAGE BODY SIZES EXCLUDE MOLD FLASH OR GATE BURRS. MOLD FLASH AT THE NON-LEAD SIDES SHOULD BE LESS THAN 6 MILS EACH. 2. TOLERANCE +0.100 mm (4 mil) UNLESS OTHERWISE SPECIFIED. 3. DIMENSION L IS MEASURED IN GAUGE PLANE. 4. CONTROLLING DIMENSION IS MILLIMETER. CONVERTED INCH DIMENSIONS ARE NOT NECESSARILY EXACT. 5. ALL DIMENSIONS ARE IN MILLIMETERS. Rev. 2.0 January 2019
www.aosmd.com
Page 13 of 15
