Datasheet SID11x2KQ SCALE-iDriver Family (Power Integrations) - 20
ManufacturerPower Integrations
DescriptionUp to 8 A Single Channel IGBT/MOSFET Gate Driver for Automotive Applications Providing Reinforced Galvanic Isolation up to 1200 V Blocking Voltage
Pages / Page22 / 20 — SID11x2KQ. MSL Table. Part Number. MSL Rating. ESD and Latch-Up Table. …
SID11x2KQ. MSL Table. Part Number. MSL Rating. ESD and Latch-Up Table. Test. Conditions. Results. IEC 60664-1 Rating Table. Parameter
SID11x2KQ MSL Table Part Number MSL Rating ESD and Latch-Up Table Test Conditions Results IEC 60664-1 Rating Table Parameter
SID11x2KQ 3
Latch-up at 125 °C AEC-Q100-002 > ±100 mA or > 1.5 × V on all pins MAX Human Body Model ESD AEC-Q100-002 > ±2000 V on all pins Charged Device Model ESD AEC-Q100-011 > ±500 V on all pins
IEC 60664-1 Rating Table Parameter Conditions Specifications
Basic Isolation Group Material Group I Rated mains voltage ≤ 150 V I - IV RMS Rated mains voltage ≤ 300 V I - IV Instal ation Classification RMS Rated mains voltage ≤ 600 V I - IV RMS Rated mains voltage ≤ 1000 V I - III RMS
Electrical Characteristics (EMI) Table Parameter Symbol Conditions Min Typ Max Units Common-Mode
Typical values measured according to Figures
Transient Immunity,
CM 33, 34. Maximum values are design values -35 / 50 -100 / 100 kV/µs H
Logic High
assuming trapezoid waveforms
Common-Mode
Transient Immunity,
CM 33, 34. Maximum values are design values -35 / 50 -100 / 100 kV/µs L
Logic Low
Variable Magnetic Field
H See Note 15 1000 HPEAK
Immunity
A/m H See Note 15 1000 LPEAK Figure 20. Applied Common Mode Pulses for Generating Negative dv/dt. Figure 21. Applied Common Mode Pulses for Generating Positive dv/dt.
20
Rev. C 09/19 www.power.com Document Outline Product Highlights Description Scale-iDriver − Product Portfolio Pin Functional Description SCALE-iDriver Functional Description Application Examples and Components Selection Power Dissipation and IC Junction Temperature Estimation Absolute Maximum Ratings Thermal Resistance Key Electrical Characteristics Typical Performance Characteristics eSOP-R16B (K Package) MSL Table ESD and Latch-Up Table IEC 60664-1 Rating Table Electrical Characteristics (EMI) Table Regulatory Information Table Part Ordering Information
