Datasheet ADP5076 (Analog Devices) - 23
Description | 2 A/1.2 A DC-to-DC Switching Regulator with Independent Positive and Negative Outputs |
Pages / Page | 23 / 23 — Data Sheet. ADP5076. OUTLINE DIMENSIONS. 1.650 1.610 1.570. 0.310 0.290. … |
Revision | A |
File Format / Size | PDF / 725 Kb |
Data Sheet. ADP5076. OUTLINE DIMENSIONS. 1.650 1.610 1.570. 0.310 0.290. 0.270. BALL A1. IDENTIFIER. 2.220. 1.60 REF. 2.180. 2.140. 0.40. BSC
Data Sheet ADP5076 OUTLINE DIMENSIONS 1.650 1.610 1.570 0.310 0.290 4 3 2 1 0.270 A BALL A1 IDENTIFIER B 2.220 1.60 REF 2.180 C 2.140 0.40 BSC D E TOP VIEW BOTTOM VIEW (BALL SIDE DOWN) 0.225 (BALL SIDE UP) 0.205 1.20 REF 0.330 0.185 0.560 0.300 0.500 SIDE VIEW 0.270 0.440 COPLANARITY 0.04 SEATING 0.300 0.230 PLANE 0.260 0.200 A 0.220 773 0.170 2017- -003 07- G K P 11-
Figure 49. 20-Ball Wafer Level Chip Scale Package [WLCSP] (CB-20-14) Dimensions shown in millimeters
ORDERING GUIDE Model1 Temperature Range Package Description Package Option
ADP5076ACBZ-R7 −40°C to +125°C 20-Ball Wafer Level Chip Scale Package [WLCSP] CB-20-14 ADP5076CB-EVALZ Evaluation Board 1 Z = RoHS Compliant Part.
©2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D20402-0-12/19(A)
Rev. A | Page 23 of 23 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PULSE WIDTH MODULATION (PWM) MODE PULSE SKIP MODULATION MODE UVLO OSCILLATOR AND SYNCHRONIZATION INTERNAL REGULATOR PRECISION ENABLING SOFT START SLEW RATE CONTROL CURRENT-LIMIT PROTECTION OVERVOLTAGE PROTECTION THERMAL SHUTDOWN STARTUP SEQUENCE APPLICATIONS INFORMATION COMPONENT SELECTION Feedback Resistors OUTPUT CAPACITORS Input Capacitor VREF Capacitor Soft Start Resistor Diodes Inductor Selection for the Boost Regulator Inductor Selection for the Inverting Regulator LOOP COMPENSATION Boost Regulator Inverting Regulator COMMON APPLICATIONS LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
