Datasheet LTC3889 (Analog Devices) - 115
Description60V Dual Output Step-Down Controller with Digital Power System Management
Pages / Page120 / 115 — PMBus COMMAND DETAILS Table 13a. Explanation of Position_Fault Values. …
PMBus COMMAND DETAILS Table 13a. Explanation of Position_Fault Values. MFR_FAULT_LOG_CLEAR. Block Memory Write/Read. DATA
PMBus COMMAND DETAILS Table 13a Explanation of Position_Fault Values MFR_FAULT_LOG_CLEAR Block Memory Write/Read DATA
LTC3889
POSITION_FAULT VALUE SOURCE OF FAULT LOG 0xFF MFR_FAULT_LOG_STORE 0x00 TON_MAX_FAULT Channel 0 0x01 VOUT_OV_FAULT Channel 0 0x02 VOUT_UV_FAULT Channel 0 0x03 IOUT_OC_FAULT Channel 0 0x05 TEMP_OT_FAULT Channel 0 0x06 TEMP_UT_FAULT Channel 0 0x07 VIN_OV_FAULT 0x0A MFR_TEMPERATURE_2_OT_FAULT 0x10 TON_MAX_FAULT Channel 1 0x11 VOUT_OV_FAULT Channel 1 0x12 VOUT_UV_FAULT Channel 1 0x13 IOUT_OC_FAULT Channel 1 0x15 OT_FAULT Channel 1 0x16 UT_FAULT Channel 1 0x17 VIN_OV_FAULT 0x1A MFR_TEMPERATURE_2_OT_FAULT
MFR_FAULT_LOG_CLEAR
The MFR_FAULT_LOG_CLEAR command will erase the fault log file stored values. It will also clear bit 3 in the STATUS_MFR_SPECIFIC command. After a clear is issued, the status can take up to 8ms to clear. This write-only command is send bytes.
Block Memory Write/Read DATA DEFAULT COMMAND NAME CMD CODE DESCRIPTION TYPE PAGED FORMAT UNITS EEPROM VALUE
MFR_EE_UNLOCK 0xBD Unlock user EEPROM for access by MFR_EE_ERASE R/W Byte N Reg NA and MFR_EE_DATA commands. MFR_EE_ERASE 0xBE Initialize user EEPROM for bulk programming by R/W Byte N Reg NA MFR_EE_DATA. MFR_EE_DATA 0xBF Data transferred to and from EEPROM using R/W N Reg NA sequential PMBus word reads or writes. Supports bulk Word programming. All the EEPROM commands are disabled if the die temperature exceeds 130°C. EEPROM commands are re-enabled when the die temperature drops below 125°C.
MFR_EE_xxxx
The MFR_EE_xxxx commands facilitate bulk programming of the LTC3889 internal EEPROM. Contact the factory for details. Rev. 0 For more information www.analog.com 115 Document Outline Table of Contents Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Overview Main Control Loop EEPROM CRC Protection Power-Up and Initialization Soft-Start Time-Based Sequencing Event-Based Sequencing Shutdown Light-Load Current Operation PWM Loop Compensation Switching Frequency and Phase Output Voltage Sensing Output Current Sensing Input Current Sensing PolyPhase Load Sharing External/Internal Temperature Sense RCONFIG (Resistor Configuration) Pins Fault Handling Status Registers and ALERT Masking Mapping Faults to FAULT Pins Power Good Pins Serial Interface Communication Protection Device Addressing Responses to VOUT and IOUT Faults Output Overvoltage Fault Response Output Undervoltage Response Peak Output Overcurrent Fault Response Responses to Timing Faults Responses to VIN OV Faults Responses to OT/UT Faults Internal Overtemperature Fault/Warn Response External Overtemperature and Undertemperature Fault Response Responses to External Faults Fault Logging Bus Timeout Protection Similarity Between PMBus, SMBus and I2C 2-Wire Interface PMBus Serial Digital Interface PMBus Command Summary PMBus Commands Applications Information Current Limit Programming ISENSE+ and ISENSE– Pins Low Value Resistor Current Sensing Inductor DCR Current Sensing Slope Compensation and Inductor Peak Current Inductor Value Calculation Inductor Core Selection Power MOSFET and Optional Schottky Diode Selection CIN and COUT Selection Variable Delay Time, Soft-Start and Output Voltage Ramping Digital Servo Mode Soft Off (Sequenced Off) DRVCC Regulator Topside MOSFET Driver Supply (CB, DB) Undervoltage Lockout Fault Indications Open-Drain Pins Phase-Locked Loop and Frequency Synchronization Minimum On-Time Considerations External Temperature Sense Derating EEPROM Retention at Temperature Input Current Sense Amplifier External Resistor Configuration Pins (RCONFIG) Voltage Selection Frequency Selection Phase Selection Address Selection Using RCONFIG Efficiency Considerations Programmable Loop Compensation Checking Transient Response PolyPhase Configuration PC Board Layout Checklist PC Board Layout Debugging Design Example Additional Design Checks Connecting the USB to I2C/SMBus/PMBus Adapter to the LTC3889 In System LTpowerPlay: An Interactive GUI for Digital Power PMBus Communication and Command Processing PMBus Command Details Addressing and Write Protect General Configuration COMMANDS On/Off/Margin PWM Configuration Voltage Input Voltage and Limits Output Voltage and Limits Output Current and Limits Input Current and Limits Temperature External Temperature Calibration Timing Timing—On Sequence/Ramp Timing—Off Sequence/Ramp Precondition for Restart Fault Response Fault Responses All Faults Fault Responses Input Voltage Fault Responses Output Voltage Fault Responses Output Current Fault Responses IC Temperature Fault Responses External Temperature Fault Sharing Fault Sharing Propagation Fault Sharing Response Scratchpad Identification Fault Warning and Status Telemetry EEPROM Memory Commands Store/Restore Fault Logging Fault Log Operation Block Memory Write/Read Typical Applications Package Description Typical Application Related Parts
