Datasheet HMC962LC4 (Analog Devices) - 5
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 7.5 - 26.5 GHz
Pages / Page6 / 5 — HMC962LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 7.5 - 26.5 GHz. Pin …
File Format / SizePDF / 374 Kb
HMC962LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 7.5 - 26.5 GHz. Pin Descriptions. Application Circuit
HMC962LC4 GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 7.5 - 26.5 GHz Pin Descriptions Application Circuit
HMC962LC4
v02.0614
pin Number function Description interface schematic T 1, 2, 4, These pins and package bottom must m GND 15, 17, 18 be connected to rf/DC ground. s This pin AC coupled 3 rfiN e - and matched to 50 ohms is 5 - 14, 19, No connection necessary. These pins may be connected to o N/C 20, 22, 24 rf/DC ground. performance will not be affected. This pin AC coupled 16 rfoUT w N and matched to 50 ohms lo s - power supply voltages for the amplifier. Bypass capacitors 21, 23 Vdd1, Vdd2 r are required. see application circuit herein. ie lif p
Application Circuit
m A Capacitor Value C1, C2 100 pf C5, C6 1000 pf C9, C10 2.2 µf Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
