Datasheet VEML4031X00 (Vishay) - 2
ManufacturerVishay
DescriptionHigh Accuracy Ambient Light Sensor With I 2C Interface
Pages / Page15 / 2 — VEML4031X00. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. …
File Format / SizePDF / 254 Kb
VEML4031X00. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. MIN. MAX. UNIT. BASIC CHARACTERISTICS. TYP. Notes
VEML4031X00 ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION SYMBOL MIN MAX UNIT BASIC CHARACTERISTICS TYP Notes
VEML4031X00
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. MAX. UNIT
Supply voltage VDD 0 3.6 V Operation temperature range Tamb -40 +110 °C Storage temperature range Tstg -40 +110 °C Total power dissipation Tamb ≤ 25 °C Ptot - 50 mW Junction temperature Tj - +110 °C
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Supply voltage VDD 2.5 3.3 3.6 V Shutdown state (1); VDD = VBUS - 0.5 - Shutdown state (1); VDD = VBUS = 3.0 V - - 1.2 Supply current IDD μA Shutdown state (1); VDD = 3.6 V, VBUS = 1.7 V - 3.1 - Active state; VDD = 3.3 V - 280 - I2C clock rate range fSCL 10 - 400 kHz VBUS = VDD Vih 0.7 x VBUS - 3.6 V I2C bus input H-level range 0.85 x VBUS ≠ VDD Vih - 3.6 V VBUS VBUS = VDD Vil -0.3 - 0.3 x VBUS V I2C bus input L-level range VBUS ≠ VDD Vil -0.3 - 0.2 x VBUS V Digital current out (low, current sink) Iol 3 - - mA Digital resolution (LSB count) (2) With ALS_GAIN = x 2, ALS_IT = 400 ms, - 0.0026 - lx/step ALS_PDDIV = 4/4 PD With ALS_GAIN = x 0.5, ALS_IT = 6.25 ms, Detectable maximum illuminance E ALS_PDDIV = 1/4 PD V max. - 172 000 - lx ALS - 4 - Dark offset (2) With ALS_GAIN = x 2, ALS_IT = 200 ms, step ALS_PDDIV = 4/4 PD IR - 4 -
Notes
(1) Light conditions: dark (2) Light conditions: EV = 100 lx with 4300K white LED
CIRCUIT BLOCK DIAGRAM VEML4031X00
ALS Integrating ADC GND 1 4 VDD IR Integrating ADC Logic and timing controller Oscillator Command Data INT registers registers control SDA 2 I2C interface 3 SCL Temperature compensation Fig. 1 - Block Diagram Rev. 1.1, 12-Mar-2025
2
Document Number: 80348 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
