Datasheet TLP5814H (Toshiba) - 4
| Manufacturer | Toshiba |
| Description | Photocoupler |
| Pages / Page | 21 / 4 — TLP5814H. 9. Recommended. Operating. Conditions. (Note). Characteristics. … |
| File Format / Size | PDF / 4.2 Mb |
TLP5814H. 9. Recommended. Operating. Conditions. (Note). Characteristics. Symbol. Note. Min. Typ. Max. Unit. Input. on-state. current. IF(ON). (Note. 1). 4.5
TLP5814H 9. Recommended Operating Conditions (Note) Characteristics Symbol Note Min Typ. Max Unit Input on-state current IF(ON) (Note 1) 4.5 � 10 mA Input off-state voltage VF(OFF) 0 � 0.8 V Supply voltage VCC (Note 1) 13 � 23 V Peak high-level output current (L/H) IOLH (Note 2) � � -2 A Peak low-level output current (H/L) IOHL (Note 2) +2 � � A Note: The recommended operating conditions are given as a design guide necessary to obtain the intended performance of the device. Each parameter is an independent value. When creating a system design using this device, the electrical characteristics specified in this data sheet should also be considered. Note: A ceramic capacitor (1 µF) should be connected between pin 8 (VCC) and pin 5 (GND) to stabilize the operation of a high-gain linear amplifier. Otherwise, this photocoupler may not switch properly. The bypass capacitor should be placed within 1 cm of each pin. Note 1: The rise and fall times of the input on-current should be less than 500 µs, and the rise and fall slopes of VCC and VEE shiuld be less than 1 V/µs. Note 2: Load capacitor (C ≤ 10 nF), VCC - VEE = 23 V, Ta ≤ 125 �, f ≤ (50) kHz, Duty = 50 %, JEDEC ompliant substrate (JESD51-7) ©2023-2025 4 2025-02-03 Toshiba Electronic Devices & Storage Corporation Rev.4.0
