Datasheet TLP5814H (Toshiba) - 5
| Manufacturer | Toshiba |
| Description | Photocoupler |
| Pages / Page | 21 / 5 — TLP5814H. 10. Electrical. Characteristics. (Note). (Unless. otherwise. … |
| File Format / Size | PDF / 4.2 Mb |
TLP5814H. 10. Electrical. Characteristics. (Note). (Unless. otherwise. specified,. Ta. =. -40. to. 125. �). Test. Characteristics. Symbol. Note. Test
TLP5814H 10. Electrical Characteristics (Note) (Unless otherwise specified, Ta = -40 to 125 �) Test Characteristics Symbol Note Test Condition Min Typ. Max Unit Circuit Input forward voltage VF � IF = 10 mA, Ta = 25 � 1.43 � 1.7 V Input forward voltage ∆VF/∆Ta � IF = 10 mA � -0.14 � mV/� temperature coefficient Input reverse current IR � VR = 5 V, Ta = 25 � � � 10 µA Input capacitance Ct � V = 0 V, f = 1 MHz, Ta = 25 � � 38 � pF Peak high-level output IOPH (Note 1) Fig. IF = 4.5 mA � -3.5 -1.7 A current 13.1.1 V8-7 = 3.5 V VCC-VEE = 23 V Peak low-level output IOPL Fig. IF = 0 mA +2.0 +4.6 � current 13.1.2 V7-5 = 3.5 V VCC-VEE = 23 V Peak high-level output IOLH � IF = 0 → 4.5 mA � -1.4 -0.7 current (L/H) VCC-VEE = 15 V Cg = 3 nF IF = 0 → 4.5 mA � -3.5 -2.0 VCC-VEE = 23 V Cg = 10 nF Peak low-level output IOHL � IF = 4.5 → 0 mA +0.7 +1.3 � current (H/L) VCC-VEE = 15 V Cg = 3 nF IF = 4.5 → 0 mA +2.0 +3.6 � VCC-VEE = 23 V Cg = 10 nF Clamp pin low level sinking ICLAMP Fig. IF = 0 mA +2.6 +3.6 � current 13.1.5 V6-5 = 2.5 V VCC-VEE = 23 V Clamp pin threshold voltage VtCLAMP � IF = 4.5 → 0 mA 2.0 2.5 3.0 V VCC-VEE = 23 V ON-state resistance RON CLAMP � ICLAMP = 2.0 A � 1.23 1.5 Ω High-level output voltage VOH Fig. IF = 4.5 mA, IO = -100 mA 22.7 � � V 13.1.3 VCC-VEE = 23 V Low-level output voltage VOL Fig. VF = 0.8 V, IO = 100 mA � � 0.2 13.1.4 VCC-VEE = 23 V High-level supply current ICCH Fig. IF = 4.5 mA, VCC-VEE = 23 V, � 3.0 5.0 mA 13.1.6 VO = Open Low-level supply current ICCL Fig. IF = 0 mA, VCC-VEE = 23 V, � 2.8 5.0 13.1.7 VO = Open Threshold input current (L/ IFLH � VCC-VEE = 15 V, VO > 1 V � 0.8 3.0 H) Threshold input voltage (H/ VFHL � VCC-VEE = 15 V, VO < 1 V 0.8 � � V L) UVLO threshold voltage VUVLO+ � IF = 4.5 mA, VCC = 0 → 23 V 11.7 12.5 13.2 VO > 1 V VUVLO- � IF = 4.5 mA, VCC = 23 → 0 V 10.2 11.0 11.7 VO < 1 V UVLO hysteresis UVLOHYS � VUVLO+-VUVLO- � 1.5 � Note: All typical values are at Ta = 25 �. Note 1: Application time ≤ 10 µs, single pulse. ©2023-2025 5 2025-02-03 Toshiba Electronic Devices & Storage Corporation Rev.4.0
