Datasheet MAX40108 (Analog Devices)
Description1V, Low-Power, Precision Operational Amplifier
Pages / Page13 / 1 — here. MAX40108. 1V, Low-Power, Precision Operational Amplifier. General …
File Format / SizePDF / 587 Kb
here. MAX40108. 1V, Low-Power, Precision Operational Amplifier. General Description. Benefits and Features. Ordering Information
Datasheet MAX40108 Analog Devices
link to page 12 Click
here
to ask about the production status of specific part numbers.
MAX40108 1V, Low-Power, Precision Operational Amplifier General Description Benefits and Features
The MAX40108 is a low-power, high-precision operational ● Supply Voltage Range: 0.9V to 3.6V amplifier (op amp) that operates with a power supply volt- ● Low 25.5μA Quiescent Current age as low as 0.9V. ● Very Low 1μV (typ) Input Offset Voltage Available in a space-saving, 1.22mmx 0.92mm, 6-bump ● Rail-to-Rail Inputs and Outputs wafer-level package (WLP) with a 0.4mm bump pitch, it is ● Internal EMI Rejection designed for use in portable, consumer, medical, and in- ● 168kHz GBW dustrial applications. ● Low Input Bias Current ● Power-Saving Shutdown Mode The MAX40108 features rail-to-rail CMOS inputs and out- ● Available in Tiny, 1.22mm x 0.92mm, 6-bump WLP puts, a 168kHz GBW consuming only 25.5µA (typ) supply and 8-pin TDFN current and 1µV (typ) zero-drift input offset voltage over time and temperature. The zero-drift feature reduces the
Ordering Information appears at end of data sheet.
high 1/f noise typically found in CMOS input operational amplifiers, making it useful for a wide variety of low-fre- quency measurement applications. The MAX40108 operates from a 0.9V to 3.6V power sup- ply voltage and is specified over the -40°C to +125°C ex- tended operating temperature range.
Applications
● Wearable Devices ● Home Medical (Blood Glucose,Weight Scale, Blood Pressure, EKG) ● Fitness and Health (Smart Watch, Heart-Rate Monitor) ● Industrial IOT (Pressure, Flow, Level, Temperature, Proximity)
Typical Application Circuit
19-100763; Rev 0; 7/20 Document Outline General Description Applications Benefits and Features Typical Application Circuit Absolute Maximum Ratings Package Information WLP TDFN Electrical Characteristics Electrical Characteristics (continued) Typical Operating Characteristics Typical Operating Characteristics (continued) Pin Configurations WLP TDFN Pin Description Pin Description (continued) Detailed Description Auto-Zero Shutdown Operation Applications Information Overview Power-Up Settling Time Capacitive-Load Stability Power Supplies and Layout Ordering Information Revision History
