Datasheet P6KE (Taiwan Semiconductor)
ManufacturerTaiwan Semiconductor
Description600W Unidirectional Transient Voltage Suppressor
Pages / Page8 / 1 — P6KE SERIES. 600W, 6.8V - 440V Transient Voltage Suppressor. FEATURES. …
File Format / SizePDF / 494 Kb
P6KE SERIES. 600W, 6.8V - 440V Transient Voltage Suppressor. FEATURES. KEY PARAMETERS. PARAMETER. VALUE. UNIT. APPLICATIONS
Datasheet P6KE Taiwan Semiconductor
P6KE SERIES
600W, 6.8V - 440V Transient Voltage Suppressor FEATURES KEY PARAMETERS
● AEC-Q101 qualified available
PARAMETER VALUE UNIT
● Excellent clamping capability ● V Low dynamic impedance WM 5.5 - 376 V ● 600W surge capability at 10/1000μs waveform V 6.12 - 462 V BR (uni - directional) ● Fast response time: Typically less than 1.0ps from 0 volt to VBR (bi - directional) 6.12 - 462 V VBR for unidirectional and 5.0ns for bidirectional ● P 600 W Typical I PK R less than 1μA above 10V ● UL recognized file # E-326243 TJ MAX 175 ● RoHS Compliant Package DO-204AC (DO-15) ● Halogen-free according to IEC 61249-2-21 Configuration Single die
● Protect sensitive circuit from damage by high voltage transients ● Lighting, ESD transient voltage protection of IC, system ● Inductive switching load protection of IC, system ● Electrical Fast Transient Immunity protection of IC, system
MECHANICAL DATA
● Case: DO-204AC (DO-15) ● Molding compound meets UL 94V-0 flammability rating ● Terminal: Pure tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 2 whisker test ● Polarity: As marked
DO-204AC (DO-15)
● Weight: 0.400g (approximately)
ABSOLUTE MAXIMUM RATINGS
(TA = 25°C unless otherwise noted)
PARAMETER SYMBOL VALUE UNIT
Non-repetitive peak impulse power dissipation with 10/1000µs waveform(1) PPK 600 W Steady state power dissipation at TA = 75°C P lead lengths .375", 9.5mm(2) D 5 W Peak forward surge current, 8.3ms single half sine-wave I superimposed on rated load for Uni-directional only(3) FSM 100 A Junction temperature TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C
Notes:
1. Non-repetitive current pulse per Fig.3 and derated above TA = 25°C per Fig.2 2. Mounted on 5 x 5 mm copper pads to each terminal 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
Devices for Bipolar Applications
1. For bidirectional use C or CA suffix for types P6KE6.8 - types P6KE440 2. Electrical characteristics apply in both directions 1 Version: P2203
