Datasheet P6KE (Taiwan Semiconductor) - 3
| Manufacturer | Taiwan Semiconductor |
| Description | 600W Unidirectional Transient Voltage Suppressor |
| Pages / Page | 8 / 3 — P6KE SERIES. ELECTRICAL SPECIFICATIONS. Breakdown. Maximum. Nominal. … |
| File Format / Size | PDF / 494 Kb |
P6KE SERIES. ELECTRICAL SPECIFICATIONS. Breakdown. Maximum. Nominal. Voltage V. Test. Stand-Off. Reverse. Clamping. Temperature. Part
P6KE SERIES
(TA = 25°C unless otherwise noted)
Breakdown Maximum Maximum Maximum Maximum Nominal Voltage V Test Stand-Off Reverse Clamping Temperature Part BR Peak Surge Voltage (V) Current I Voltage V Leakage Voltage Coefficient of Number T WM Current I (V) (mA) (V) I PP D@ VWM V V Min Max (A) C@ IPPM BR (μA) (V) (%/°C)
P6KE68A 68 64.6 71.4 1 58.1 1 6.8 92.0 0.104 P6KE75 75 67.5 82.5 1 60.7 1 5.8 108 0.105 P6KE75A 75 71.3 78.8 1 64.1 1 6.1 103 0.105 P6KE82 82 73.8 90.2 1 66.4 1 5.3 118 0.105 P6KE82A 82 77.9 86.1 1 70.1 1 5.5 113 0.105 P6KE91 91 81.9 100 1 73.7 1 4.8 131 0.106 P6KE91A 91 86.5 95.5 1 77.8 1 5.0 125 0.106 P6KE100 100 90 110 1 81.0 1 4.3 144 0.106 P6KE100A 100 95 105 1 85.5 1 4.5 137 0.106 P6KE110 110 99 121 1 89.2 1 3.9 158 0.107 P6KE110A 110 105 116 1 94.0 1 4.1 152 0.107 P6KE120 120 108 132 1 97.2 1 3.6 173 0.107 P6KE120A 120 114 126 1 102 1 3.8 165 0.107 P6KE130 130 117 143 1 105 1 3.3 187 0.107 P6KE130A 130 124 137 1 111 1 3.5 179 0.107 P6KE150 150 135 165 1 121 1 2.9 215 0.108 P6KE150A 150 143 158 1 128 1 3.0 207 0.108 P6KE160 160 144 176 1 130 1 2.7 230 0.108 P6KE160A 160 152 168 1 136 1 2.8 219 0.108 P6KE170 170 153 187 1 138 1 2.5 244 0.108 P6KE170A 170 162 179 1 145 1 2.6 234 0.108 P6KE180 180 162 198 1 146 1 2.4 258 0.108 P6KE180A 180 171 189 1 154 1 2.5 246 0.108 P6KE200 200 180 220 1 162 1 2.1 287 0.108 P6KE200A 200 190 210 1 171 1 2.2 274 0.108 P6KE220 220 198 242 1 175 1 1.8 344 0.108 P6KE220A 220 209 231 1 185 1 1.9 328 0.108 P6KE250 250 225 275 1 202 1 1.7 360 0.110 P6KE250A 250 237 263 1 214 1 1.8 344 0.110 P6KE300 300 270 330 1 243 1 1.4 430 0.110 P6KE300A 300 285 315 1 256 1 1.5 414 0.110 P6KE350 350 315 385 1 284 1 1.2 504 0.110 P6KE350A 350 332 368 1 300 1 1.3 482 0.110 P6KE400 400 360 440 1 324 1 1.0 574 0.110 P6KE400A 400 380 420 1 342 1 1.1 548 0.110 P6KE440 440 396 484 1 356 1 1.0 631 0.110 P6KE440A 440 418 462 1 376 1 1.04 602 0.110
Notes:
1. VBR measure after IT applied for 300μs, IT = square wave pulse or equivalent. 2. Surge current waveform per Fig.3 and derate per Fig.2 3. For bipolar types having VWM of 10 volts and under, the ID limit is doubled. 4. All terms and symbols are consistent with ANSI/IEEE C62.35 3 Version: P2203
