Datasheet DMMT3904W (Diodes) - 2
| Manufacturer | Diodes |
| Description | Dual NPN, 40V, 0.2A, SOT363 |
| Pages / Page | 6 / 2 — DMMT3904W. Absolute Maximum Ratings. Characteristic. Symbol. Value. Unit. … |
| File Format / Size | PDF / 619 Kb |
DMMT3904W. Absolute Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics – Total Device. ESD Ratings
DMMT3904W Absolute Maximum Ratings
(@TA = +25°C, unless otherwise specified.)
Characteristic Symbol Value Unit
Collector-Base Voltage VCBO 60 V Collector-Emitter Voltage VCEO 40 V Emitter-Base Voltage VEBO 6.0 V Collector Current IC 200 mA
Power Dissipation (Note 6) Total Device PD 200 mW Thermal Resistance, Junction to Ambient (Note 6) RθJA 625 °C/W Operating and Storage Temperature Range TJ, TSTG -65 to +150 °C
ESD Ratings
(Note 7)
Characteristic Symbol Value Unit JEDEC Class
Electrostatic Discharge - Human Body Model ESD HBM 4,000 V 3A Electrostatic Discharge - Machine Model ESD MM 400 V C Notes: 6. For a device mounted on minimum recommended pad layout with 1oz copper that is on a single-sided 1.6mm FR-4 PCB; the device is measured under still air conditions whilst operating in a steady-state. 7. Refer to JEDEC specification JESD22-A114 and JESD22-A115.
) See Note 6 W (m N IO T A IP S IS D R E W O , PD P Figure 1. DMMT3904W 2 of 6 June 2022 Document number: DS30311 Rev. 15 - 2
www.diodes.com
© 2022 Copyright Diodes Incorporated. All Rights Reserved.
