Datasheet DMMT3904W (Diodes) - 3
| Manufacturer | Diodes |
| Description | Dual NPN, 40V, 0.2A, SOT363 |
| Pages / Page | 6 / 3 — DMMT3904W. Electrical Characteristics. Characteristic. Symbol. Min. Typ. … |
| File Format / Size | PDF / 619 Kb |
DMMT3904W. Electrical Characteristics. Characteristic. Symbol. Min. Typ. Max. Unit. Test Condition. OFF CHARACTERISTICS
DMMT3904W Electrical Characteristics
(@TA = +25°C, unless otherwise specified.)
Characteristic Symbol Min Typ Max Unit Test Condition OFF CHARACTERISTICS
Collector-Base Breakdown Voltage BVCBO 60 V IC = 100µA, IE = 0 Collector-Emitter Breakdown Voltage (Note 8) BVCEO 40 V IC = 1.0mA, IB = 0 Emitter-Base Breakdown Voltage BVEBO 6.0 V IE = 100µA, IC = 0 Collector Cutoff Current ICEX 50 nA VCE = 30V, VEB(OFF) = 3.0V Base Cutoff Current IBL 50 nA VCE = 30V, VEB(OFF) = 3.0V
ON CHARACTERISTICS (Note 8)
40 IC = 100µA, VCE = 1.0V 70 IC = 1.0mA, VCE = 1.0V DC Current Gain hFE 100 300 IC = 10mA, VCE = 1.0V 60 IC = 50mA, VCE = 1.0V 30 IC = 100mA, VCE = 1.0V 200 IC = 10mA, IB = 1.0mA Collector-Emitter Saturation Voltage VCE(sat) mV 300 IC = 50mA, IB = 5.0mA 650 850 IC = 10mA, IB = 1.0mA Base-Emitter Saturation Voltage V BE(sat) mV 950 IC = 50mA, IB = 5.0mA
MATCHING CHARACTERISTICS
DC Current Gain Matching (Note 9) hFE1 / hFE2 1 2 % IC = 2mA, VCE = 5V Base-Emitter Voltage Matching (Note 10) VBE1 - VBE2 1 2 mV IC = 2mA, VCE = 5V VCE(sat)1 / Collector-Emitter Saturation Voltage (Note 9) 1 2 % IC = 10mA, IB = 1.0mA VCE(sat)2 VBE(sat)1 / Base-Emitter Saturation Voltage (Note 9) 1 2 % IC = 10mA, IB = 1.0mA VBE(sat)2
SMALL SIGNAL CHARACTERISTICS
Output Capacitance Cobo 4.0 pF VCB = 5.0V, f = 1.0MHz, IE = 0 Input Capacitance Cibo 8.0 pF VEB = 0.5V, f = 1.0MHz, IC = 0 Input Impedance hie 1.0 10 kΩ Voltage Feedback Ratio hre 0.5 8 x 10-4 VCE = 10V, IC = 1.0mA, Small Signal Current Gain h f = 1.0kHz fe 100 400 Output Admittance hoe 1.0 40 µS V Current Gain-Bandwidth Product f CE = 20V, IC = 10mA, T 300 MHz f = 100MHz VCE = 5.0V, IC = 100µA, Noise Figure NF 5.0 dB RS = 1.0kΩ, f = 1.0kHz
SWITCHING CHARACTERISTICS
Delay Time td 35 ns VCC = 3.0V, IC = 10mA, Rise Time t V r 35 ns BE(on) = -0.5V, IB1 = 1.0mA Storage Time ts 200 ns VCC = 3.0V, IC = 10mA, Fall Time t IB1 = -IB2 = 1.0mA f 50 ns Notes: 8. Measured under pulsed conditions. Pulse width ≤ 300µs. Duty cycle ≤ 2%. 9. Is the ratio of one transistor compared to the other transistor. 10. VBE1 - VBE2 is the absolute difference of one transistor compared to the other transistor. DMMT3904W 3 of 6 June 2022 Document number: DS30311 Rev. 15 - 2
www.diodes.com
© 2022 Copyright Diodes Incorporated. All Rights Reserved.
