TFPT www.vishay.com Vishay STANDARD RESISTANCE VALUES at 25 °C in Ω 100 180 330 560 1.0K 1.8K 3.3K 5.0K 8.2K 120 220 390 680 1.2K 2.2K 3.9K 5.6K 10.0K 150 270 470 820 1.5K 2.7K 4.7K 6.8K GLOBAL PART NUMBER INFORMATION Global Part Numbering: TFPT1206L1002FM (preferred part number format)TFPT1206L1002FM GLOBAL MODEL CHARACTERISTIC RESISTANCE VALUE TOLERANCE CODE PACKAGING (1) TFPT0603L = linear 1002 = 10K D = ± 0.5 % M = paper tape on reel, code ET1 (5000 pcs) TFPT08051001 = 1K F = ± 1 % V = paper tape on reel, code E52 (1000 pcs) TFPT12061000 = 100R J = ± 5 % Note (1) According IEC 60286-3: 8 mm paper tape on Ø 180 mm / 7" reel DIMENSIONS in millimeters CONSTRUCTIONADOvercoatingNickel filmBCEPART NUMBERABCDEAlumina substrate 1.55 0.80 0.45 0.30 0.30 Inner electrode TFPT 0603 ± 0.10 ± 0.10 ± 0.10 ± 0.20 ± 0.20 Nickel barrier 2.00 1.25 0.45 0.40 0.40 TFPT 0805 Solderable coating ± 0.15 ± 0.15 ± 0.10 ± 0.20 ± 0.20 (pure matte tin termination finish) 3.05 1.50 0.55 0.50 0.50 TFPT 1206 ± 0.15 ± 0.15 ± 0.10 ± 0.25 ± 0.25 TESTS AND REQUIREMENTSTESTCONDITIONS (1)REQUIREMENTSMAX. | Δ R25/R25| High temperature exposure (storage) AEC-Q200, 1000 h at 150 °C 0.25 % Temperature cycling AEC-Q200, 1000 cycles -55 °C / +125 °C 0.25 % 1000 h, 1 mA biased at 85 °C / 85 % RH 0.25 % Biased humidity 1000 h, 1 mA biased at 40 °C / 95 % RH 0.25 % Operational life 1000 h, 10 % of P70 max biased at 85 °C 0.25 % Mechanical shock MIL-STD 202, method 213 0.25 % Mechanical vibration MIL-STD 202, method 204 0.25 % Resistance to soldering heat MIL-STD 202, method 210, condition K (reflow soldering) 0.25 % ESD (2) AEC-Q200-002, HBM (CD) 0.5 kV (0603), 1.0 kV (0805), 1.0 kV (1206) 0.25 % Board flex AEC-Q200-005, 2 mm during 60 s 0.25 % Terminal strength AEC-Q200-006, shear test 17.7 N (0805, 1206) and 10 N (0603) during 60 s 0.25 % Notes (1) Environmental performance specifications use test procedures as outlined in MIL-R23648D, MIL-STD 202 and AEC-Q200 (2) TFPTs are ESD sensitive Revision: 25-Feb-2025 2 Document Number: 33017 For technical questions, contact: nlr@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
