G9H Accessories (Order Separately)Socket CharacteristicsModelRatedDielectric strengthInsulationRemarkscarry currentresistance * 1 Between contact terminals of different polarity: 2,000 VAC, 1 min PTF-08-PU 10 A Between contact terminals of same polarity: 2,000 VAC, 1 min 1,000 MΩ min. Between coil and contact terminals: 2,000 VAC, 1 min Between contact terminals of different polarity: 2,500 VAC, 1 min Between contact terminals of same polarity: 2,500 VAC, 1 min PTFZ-08-E 12 A (@70°C) *2 1,000 MΩ min. Between ground terminals: 2,500 VAC, 1 min Between coil and contact terminals: 2,500 VAC, 1 min PTF08A 10 A Between terminals: 2,000 VAC for 1 min 100 MΩ min. PT-08 10 A Between terminals: 2,000 VAC for 1 min 100 MΩ min. PT08-0 10 A Between terminals: 2,000 VAC for 1 min 100 MΩ min. PT08QN 10 A Between terminals: 2,000 VAC for 1 min 100 MΩ min. *1 The insulation resistance was measured with a 500-VDC insulation resistance meter at the same places as those used for measuring the di- electric strength. *2 However, do not exceed the continuous carry current of the socket to be mounted. Connection SocketsDimensionsTerminal Arrangement/Mounting Hole DimensionsInternal ConnectionsPTF-08-PU Two, M3 screw hole or 66.2 two, 3.5 dia. hole 48.2 21 11 (6) (5) 45 24 14 36.3 (4) (3) 27.6 3.9 22 12 (2) (1) (4.2) 108 90 35.3 (8) (7) A2 A1 (Top View) 27.4 Release lever Note: The numbers in (4.2) parentheses are (Top View) 24.8 27.6 traditionally used 28.1 terminal numbers. Note: Pull out the hooks to mount the Relay with screws. 30.3 PTF08A Two, 4.5 dia. or M4 mounting holes Two, 4.5 × 6 7±0.2 3.4 mounting holes 8-M3.5×8 2 1 4 3 68±0.3 78.5 max. 35.5 6 5 8 7 19±0.2 (Top View) (Top View) 8 28.5 max. 30 max. Note: Track mounting is also possible. 6
