Datasheet HC-05 (Silicon Microstructures) - 10
| Manufacturer | Silicon Microstructures |
| Description | Bluetooth to Serial Port Module |
| Pages / Page | 13 / 10 — Tech Support: info@iteadstudio.com |
| File Format / Size | PDF / 861 Kb |
OK cure 2——sec_mode2_service 3——sec_mode3_link 4——sec_mode_unknow n Param2: 0——hci_enc_mode_off 1——hci_enc_mode_pt_t o_pt 2——hci_enc_mode_pt_t o_pt_and_bcast 21. Delete Authenticated Device Command Respond Parameter AT+PMSAD=<Param> OK Param: Authenticated Device Address Example: AT+PMSAD =1234,56,abcdef\r\n OK 22. Delete All Authenticated Device Command Respond Parameter AT+ RMAAD OK - 23. Search Authenticated Device Command Respond Parameter AT+FSAD=<Param> 1. OK Param: Device address 2. FAIL 24. Get Authenticated Device Count Command Respond Parameter AT+ADCN? +ADCN:<Param> Param: Device Count OK 25. Most Recently Used Authenticated Device Command Respond Parameter AT+MRAD? + MRAD:<Param> Param: Recently OK Authenticated Device Address 26. Get the module working state Command Respond Parameter HC-05 Bluetooth module iteadstudio.com 06.18.2010
