Datasheet SN74LVC1G16 (Texas Instruments) - 4
| Description | One-channel 1.65V-to-5.5V inverter with open-drain outputs and Schmitt-trigger inputs |
| Pages / Page | 30 / 4 — SN74LVC1G16. www.ti.com. 5 Specifications 5.1 Absolute Maximum Ratings. … |
SN74LVC1G16. www.ti.com. 5 Specifications 5.1 Absolute Maximum Ratings. MIN. MAX. UNIT. 5.2 ESD Ratings. VALUE
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
SN74LVC1G16
SCLSA29B – OCTOBER 2024 – REVISED MAY 2025
www.ti.com 5 Specifications 5.1 Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted)(1)
MIN MAX UNIT
VCC Supply voltage range -0.5 6.5 V VI Input voltage range(2) -0.5 6.5 V VO Output voltage range(2) -0.5 VCC + 0.5 V VO Output voltage range (2) -0.5 6.5 V IIK Input clamp current VI < 0 V -50 mA IOK Output clamp current VO < 0 V -50 mA IO Continuous output current ±50 mA IO Continuous output current through VCC or GND ±100 mA TJ Junction temperature -65 150 °C Tstg Storage temperature -65 150 °C (1) Operation outside the Absolute Maximum Ratings may cause permanent device damage. Absolute maximum ratings do not imply functional operation of the device at these or any other conditions beyond those listed under Recommended Operating Conditions. If briefly operating outside the Recommended Operating Conditions but within the Absolute Maximum Ratings, the device may not sustain damage, but it may not be fully functional. Operating the device in this manner may affect device reliability, functionality, performance, and shorten the device lifetime. (2) The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
5.2 ESD Ratings VALUE UNIT
Electrostatic Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001(1) ±2000 V(ESD) V discharge Charged-device model (CDM), per ANSI/ESDA/JEDEC JS-002(2) ±1000 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
5.3 Recommended Operating Conditions
Specifications Description Condition MIN MAX UNIT
Operating 1.65 5.5 VCC Supply voltage V Functional 1.2 VI Input voltage 0 5.5 V VO Output voltage (High or low state) 0 VCC V VCC = 1.65 V -4 VCC = 2.3 V -8 IOH High-level output current -16 mA VCC = 3.0 V -24 VCC = 4.5 V -32 VCC = 1.65 V 4 VCC = 2.3 V 8 IOL Low-level output current 16 mA VCC = 3.0 V 24 VCC = 4.5 V 32 Δt/Δv Input transition rise or fall rate Vcc = 1.1 V to 5.5V 100 ms/V 4 Submit Document Feedback Copyright © 2025 Texas Instruments Incorporated Product Folder Links: SN74LVC1G16 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configuration and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 Recommended Operating Conditions 5.4 Thermal Information 5.5 Electrical Characteristics 5.6 Switching Characteristics 5.7 Typical Characteristics 6 Parameter Measurement Information 7 Overview 8 Functional Block Diagram 9 Detailed Description 9.1 Feature Description 9.1.1 Open-Drain CMOS Outputs 9.1.2 CMOS Schmitt-Trigger Inputs 9.1.3 Clamp Diode Structure 10 Application and Implementation 10.1 Application Information 10.2 Typical Application 10.2.1 Design Requirements 10.2.1.1 Power Considerations 10.2.1.2 Input Considerations 10.2.1.3 Output Considerations 10.2.2 Detailed Design Procedure 10.3 Application Curves 10.4 Power Supply Recommendations 10.5 Layout 10.5.1 Layout Guidelines 10.5.2 Layout Example 11 Device and Documentation Support 11.1 Documentation Support 11.1.1 Related Documentation 11.2 Receiving Notification of Documentation Updates 11.3 Support Resources 11.4 Trademarks 11.5 Electrostatic Discharge Caution 11.6 Glossary 12 Revision History 13 Mechanical, Packaging, and Orderable Information
