Datasheet CMHZ5221B - CMHZ5267B (Central Semiconductor)
| Manufacturer | Central Semiconductor |
| Description | 500mW Surface mount Diode-Zener Single in SOD-123 package |
| Pages / Page | 3 / 1 — CMHZ5221B THRU CMHZ5267B. SURFACE MOUNT. www.centra lsemi.com. SILICON … |
| File Format / Size | PDF / 408 Kb |
CMHZ5221B THRU CMHZ5267B. SURFACE MOUNT. www.centra lsemi.com. SILICON ZENER DIODE. 2.4 VOLTS THRU 75 VOLTS. DESCRIPTION:
CMHZ5221B THRU CMHZ5267B SURFACE MOUNT www.centra lsemi.com SILICON ZENER DIODE 2.4 VOLTS THRU 75 VOLTS DESCRIPTION: 500mW, 5% TOLERANCE
The CENTRAL SEMICONDUCTOR CMHZ5221B Series Silicon Zener Diode is a high quality voltage regulator, manufactured in a surface mount package, designed for use in industrial, commercial, entertainment and computer applications.
MARKING CODE: SEE MARKING CODE ON ELECTRICAL CHARACTERISTIC TABLE SOD-123 CASE MAXIMUM RATINGS: SYMBOL UNIT
Power Dissipation (@TL=75°C) PD 500 mW Maximum Operating Junction Temperature TJ +150 °C Storage Temperature Tstg -65 to +175 °C Thermal Resistance ΘJL 150 °C/W Note: VZ Tolerance “B” suffix = ±5%, VZ Tolerance “C” suffix = ±2%, VZ Tolerance “D” suffix = ±1%
ELECTRICAL CHARACTERISTICS:
(TA=25°C), VF=0.9V MAX @ IF=10mA (for all types)
ZENER TEST MAXIMUM ZENER MAXIMUM MAX. MARKING VOLTAGE CURRENT IMPEDANCE REVERSE TEMP. CODE TYPE VZ @ IZT CURRENT COEFF. MIN NOM MAX IZT ZZT @ IZT ZZK @ IZK IR @ VR
Θ
VZ V V V mA Ω Ω mA µA V %/°C
CMHZ5221B 2.280 2.4 2.520 20 30 1200 0.25 100 1.0 -0.085 CC1 CMHZ5222B 2.375 2.5 2.625 20 30 1250 0.25 100 1.0 -0.085 CC2 CMHZ5223B 2.565 2.7 2.835 20 30 1300 0.25 75 1.0 -0.080 CC3 CMHZ5224B 2.660 2.8 2.940 20 30 1400 0.25 75 1.0 -0.080 CC4 CMHZ5225B 2.850 3.0 3.150 20 30 1600 0.25 50 1.0 -0.075 CC5 CMHZ5226B 3.135 3.3 3.465 20 28 1600 0.25 25 1.0 -0.070 CD1 CMHZ5227B 3.420 3.6 3.780 20 24 1700 0.25 15 1.0 -0.065 CD2 CMHZ5228B 3.705 3.9 4.095 20 23 1900 0.25 10 1.0 -0.060 CD3 CMHZ5229B 4.085 4.3 4.515 20 22 2000 0.25 5.0 1.0 ±0.055 CD4 CMHZ5230B 4.465 4.7 4.935 20 19 1900 0.25 5.0 2.0 ±0.030 CD5 CMHZ5231B 4.845 5.1 5.355 20 17 1600 0.25 5.0 2.0 ±0.030 CE1 CMHZ5232B 5.320 5.6 5.880 20 11 1600 0.25 5.0 3.0 +0.038 CE2 CMHZ5233B 5.700 6.0 6.300 20 7.0 1600 0.25 5.0 3.5 +0.038 CE3 CMHZ5234B 5.890 6.2 6.510 20 7.0 1000 0.25 5.0 4.0 +0.045 CE4 CMHZ5235B 6.460 6.8 7.140 20 5.0 750 0.25 3.0 5.0 +0.050 CE5 CMHZ5236B 7.125 7.5 7.875 20 6.0 500 0.25 3.0 6.0 +0.058 CF1 CMHZ5237B 7.790 8.2 8.610 20 8.0 500 0.25 3.0 6.5 +0.062 CF2 CMHZ5238B 8.265 8.7 9.135 20 8.0 600 0.25 3.0 6.5 +0.065 CF3 CMHZ5239B 8.645 9.1 9.555 20 10 600 0.25 3.0 7.0 +0.068 CF4 CMHZ5240B 9.500 10 10.50 20 17 600 0.25 3.0 8.0 +0.075 CF5 CMHZ5241B 10.45 11 11.55 20 22 600 0.25 2.0 8.4 +0.076 CH1 CMHZ5242B 11.40 12 12.60 20 30 600 0.25 1.0 9.1 +0.077 CH2 CMHZ5243B 12.35 13 13.65 9.5 13 600 0.25 0.5 9.9 +0.079 CH3 CMHZ5244B 13.30 14 14.70 9.0 15 600 0.25 0.1 10 +0.082 CH4 CMHZ5245B 14.25 15 15.75 8.5 16 600 0.25 0.1 11 +0.082 CH5 CMHZ5246B 15.20 16 16.80 7.8 17 600 0.25 0.1 12 +0.083 CJ1 CMHZ5247B 16.15 17 17.85 7.4 19 600 0.25 0.1 13 +0.084 CJ2 CMHZ5248B 17.10 18 18.90 7.0 21 600 0.25 0.1 14 +0.085 CJ3 CMHZ5249B 18.05 19 19.95 6.6 23 600 0.25 0.1 14 +0.086 CJ4 CMHZ5250B 19.00 20 21.00 6.2 25 600 0.25 0.1 15 +0.086 CJ5 CMHZ5251B 20.90 22 23.10 5.6 29 600 0.25 0.1 17 +0.087 CK1 CMHZ5252B 22.80 24 25.20 5.2 33 600 0.25 0.1 18 +0.087 CK2 CMHZ5253B 23.75 25 26.25 5.0 35 600 0.25 0.1 19 +0.089 CK3 R10 (18-January 2024)
